Scott Fella Mon, 05/31/2010 - 13:28
Have you tried to put the AP on the same subnet as the management and ap-managers.  This is one of the easiest ways to make sure the ap joins the wlc.  If the ap still doesn't join, then console into the ap and log the join proccess and post it.
Scott
Leo Laohoo Mon, 05/31/2010 - 15:11
What is your firmware?
Can you provide logs on the WLC and the 1250?
Can you the AP ping the Management IP Address of the WLC?  If yes, console into the AP and in enable mode enter the command "config lwapp ap controller ".  If no, then why not?
