LMS 3.2/ CS : switch 6500 are discovered by several IP@
May 31st, 2010
We have two 6513 switchs (6500-1 and 6500-2), each has a management IP@ but CS discovers both by managment IP@ and other ip@ which are defined on 6500 switch:
on dcr :
discover by admin Vlan :
6500-1 xx.xx.100.10
6500-2 xx.xx.150.10
and with other ip :
xx.xx.200.98 xx.xx.200.98 for 6500-1
xx.xx.200.99 xx.xx.200.99 for 6500-2
Dns configuration:
6500-1 has xx.xx.100.10 and xx.xx.200.98 defined
6500-2 has xx.xx.150.10 and xx.xx.200.99 defined
Acs :
@ip are defined in acs.
You will find discovery configuration.
Many thanks, Elisabeth
Joe Clarke Mon, 05/31/2010 - 19:17
In order to diagnose this, you will need to provide the show run from both switches.  You will also need to provide the output of an SNMP Walk of the ipAddrTable from both switches.
ebezombes Tue, 06/01/2010 - 03:20
For security reasons, I can't forward all information from show run, what information do you need ?
Joe Clarke Tue, 06/01/2010 - 08:53
If you cannot post the information to the forum, open a TAC service request and provide the configs and ipAddrTable SNMP Walk output.
