SRST Unity Connection Configuration
May 31st, 2010
Hi all:
I would much appreciate if some one walk me through the steps to have Unity Connection voice mail in SRST mode.
I am not able to make it work the unity connection in SRST, however I made partially to work with VM-Integartion command
Please if you have done it and have the steps, Please give me some knowledge
thanks
Md. Mijanur Rahman Tue, 06/01/2010 - 02:19
  • Silver, 250 points or more
Hi, forget about those vm-integration commads, follow the procedures below (if you are using call-manager-fallback SRST):
voicemail 2342222 ! i guessed your original VM Pilot number is 2222 and 234 is the CUCM/Connection site access code, you got me?
call-forward noan 2342222 timeout 20
call-forward busy 2342222
You will need a seperate dial-peer for that:
dial-peer voice 2222 pots
destination-pattern 2342222
port x/y:0
forward-digit all
Now another important thing is don't forget to mark the 'Redirecting Number IE Delivery - Inbound' if there is MGCP gateway on main site, if it's H.323 then put the command 'isdn outgoing ie redirecting-number ' on voice serial interface.
Keep in mind your MWI won't work for SRST like your model.
If you are using CME SRST, configure like below:
Telephony-service
voicemail 2342222
ephone-dn-template 1
ephone-dn 1 octo-line
You will need the dial-peer as well.
HTH.
waqas sardar Fri, 08/14/2015 - 05:16
Hi Md. Mijanur Rahman
Client have CUCM 10.5 and Unity connection 10.5 (attached screenshot) and Voice Gateway is configured as mgcp in HQ .
Issue is voicemail is not working in case on fallback. Please see the below configuration and let me know whats missing
I
no aaa new-model
clock timezone GMT 4 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip dhcp pool ipphones
 network 192.168.210.0 255.255.255.0
 default-router 192.168.210.1
 option 150 ip 192.168.210.10
 domain-name wr
ip domain name NLJcapital.kwi
ip cef
no ipv6 cef
isdn switch-type primary-net5
cts logging verbose
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 modem passthrough nse codec g711ulaw
 h323
 sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
  no silent-discard untrusted
voice register global
 mode srst
 timeouts interdigit 7
 max-dn 10
 max-pool 40
voice translation-rule 7
 rule 1 /^2/ /043652/
voice translation-rule 9
 rule 1 /^1/ /91/
 rule 2 /^2/ /902/
 rule 3 /^3/ /903/
 rule 4 /^4/ /904/
 rule 5 /^5/ /905/
 rule 6 /^6/ /906/
 rule 7 /^7/ /907/
 rule 8 /^8/ /98/
 rule 9 /^9/ /9009/
 rule 10 /^0/ /90/
voice translation-rule 10
 rule 1 /^1/ /83041/
 rule 2 /^2/ /83042/
 rule 3 /^3/ /83043/
 rule 4 /^4/ /83044/
 rule 5 /^5/ /83045/
 rule 6 /^6/ /83046/
 rule 7 /^7/ /83047/
 rule 8 /^8/ /83048/
 rule 9 /^9/ /83049/
 rule 10 /^0/ /83040/
voice translation-rule 11
 rule 1 /^1/ /83651/
 rule 2 /^2/ /83652/
 rule 3 /^3/ /83653/
 rule 4 /^4/ /83654/
 rule 5 /^5/ /83655/
 rule 6 /^6/ /83656/
 rule 7 /^7/ /83657/
 rule 8 /^8/ /83658/
 rule 9 /^9/ /83659/
 rule 10 /^0/ /83650/
voice translation-profile Add9
 translate calling 9
voice translation-profile CALL-KWT
 translate calling 10
voice translation-profile CALL-NLJBranches
voice translation-profile change_calling
 translate calling 7
application
 global
  service alternate default
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31 service mgcp
ip ssh authentication-retries 5
ip ssh version 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip address 192.168.210.11 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 isdn bind-l3 ccm-manager
 isdn outgoing display-ie
 no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.210.1
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp
mgcp call-agent 192.168.210.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.210.10 identifier 1 priority 1 version 7.0
sccp ccm 192.168.210.11 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register HQ-CONF
 associate profile 2 register HQ-XCODE
ccm-manager music-on-hold
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config
dspfarm profile 2 transcode universal
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729br8
 codec g729r8
 codec ilbc
 codec pass-through
 maximum sessions 3
 associate application SCCP
dspfarm profile 1 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec ilbc
 maximum sessions 2
dial-peer voice 1 pots
 translation-profile incoming Add9
 preference 7
 destination-pattern 9.T
 incoming called-number .
 direct-inward-dial
 port 0/0/0:15
 forward-digits all
dial-peer voice 101 pots
 translation-profile outgoing change_calling
 preference 3
 destination-pattern 9(050.......)
 progress_ind setup enable 3
 progress_ind alert enable 8
 progress_ind progress enable 8
 progress_ind connect enable 8
 translate-outgoing calling 7
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 102 pots
 preference 2
 destination-pattern 9([2,3,4,5]......)
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 103 pots
 preference 1
 destination-pattern 9(0[2,3,6,7].......)
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 104 pots
 destination-pattern 9T
 direct-inward-dial
 port 0/0/0:15
dial-peer voice 165 pots
 preference 3
 destination-pattern 9(055.......)
 direct-inward-dial
 port 0/0/0:15
num-exp 2800 2824
gatekeeper
 shutdown
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 192.168.210.11 port 2000
 max-ephones 75
 max-dn 152 dual-line
 keepalive 20
 voicemail 5000
 call-forward busy 5000
 call-forward noan 5000 timeout 20
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input all
scheduler allocate 20000 1000
ntp master 2
end
