Unstable RDP sessions
May 31st, 2010
Hi all,
User A can login into server B via RDP (tcp 3389) however he cannot copy the file from server B via remote desktop.He also can ping and do a traceroute to the server.
When I do a testing with him, I’ve found out the following message on ASA. This is the only message that I saw on the firewall. %ASA-2-106001: Inbound TCP connection denied from
ASA-fw# sh log | grep 1.1.1.1
Jun 01 2010 08:46:00 3.3.3.3 : %ASA-2-106001: Inbound TCP connection denied from 1.1.1.1/1852 to 2.2.2.2/3389 flags PSH ACK  on interface inside
Let say
User A = 1.1.1.1
Server B = 2.2.2.2
New Fw ASA = 3.3.3.3
Fw is allowed RDP connection from user A to Server B.Here are the rules on the firewall related to the server B.
object-group service Standard_Remote_Access
service-object tcp eq telnet
service-object tcp eq ssh
service-object tcp eq https
service-object tcp eq www
service-object tcp eq 3389
access-list acl-in extended permit object-group Standard_Remote_Access  any object-group Network_2.2.2.2_24
This problem only occured after New Fw ASA installed between the user A and server B. Any advice would be appreciated. Thanks
Adam David Sun, 06/13/2010 - 22:34
Thanks Marcin for your suggestion.
RDP client version is 5.1(Build 2600), Control Version 5.1.2600.3627
RDPserver version is 5.2.3790.3959 <-- I'm not sure whether this is correct or not? May I know how to check the version of RDP server?
I did the packet capture and here is the result...
Packet 1-3: TCP Three way handshake
1: 10:05:27.279373 1.1.1.1.5555 > 2.2.2.2.3389: S 945100646:945100646(0) win 64512 <[|tcp]>
   2: 10:05:27.280381 2.2.2.2.3389 > 1.1.1.1.5555: S 2051713410:2051713410(0) ack 945100647 win 16384 <[|tcp]>
   3: 10:05:27.280548 1.1.1.1.5555 > 2.2.2.2.3389: . ack 2051713411 win 64860
The next packet: Data transfer
   4: 10:05:27.280731 1.1.1.1.5555 > 2.2.2.2.3389: P 945100647:945100685(38) ack 2051713411 win 64860
   5: 10:05:27.282273 2.2.2.2.3389 > 1.1.1.1.5555: P 2051713411:2051713422(11) ack 945100685 win 65497
   6: 10:05:27.282517 1.1.1.1.5555 > 2.2.2.2.3389: P 945100685:945101097(412) ack 2051713422 win 64849
   7: 10:05:27.283859 2.2.2.2.3389 > 1.1.1.1.5555: P 2051713422:2051713759(337) ack 945101097 win 65085
   8: 10:05:27.284119 1.1.1.1.5555 > 2.2.2.2.3389: P 945101097:945101109(12) ack 2051713759 win 64512
   9: 10:05:27.284164 1.1.1.1.5555 > 2.2.2.2.3389: P 945101109:945101117(8) ack 2051713759 win 64512
  10: 10:05:27.284851 2.2.2.2.3389 > 1.1.1.1.5555: . ack 945101117 win 65065
Everything looks normal untill packet number 511. User sents a few PUSH packet to the server, but the server never reply.
511: 10:06:32.454215 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295239:457295635(396) ack 3592134313 win 64860
512: 10:06:32.738258 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295121:457295635(514) ack 3592134313 win 64860
513: 10:06:33.285156 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295121:457295635(514) ack 3592134313 win 64860
514: 10:06:33.557145 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295635:457295657(22) ack 3592134313 win 64860
515: 10:06:33.665981 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295657:457295758(101) ack 3592134313 win 64860
516: 10:06:33.802158 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295758:457295838(80) ack 3592134313 win 64860
517: 10:06:33.953869 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295838:457295862(24) ack 3592134313 win 64860
518: 10:06:34.394739 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295862:457295928(66) ack 3592134313 win 64860
519: 10:06:34.488256 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295121:457295657(536) ack 3592134313 win 64860
520: 10:06:36.894423 1.1.1.1.5.5.5.5 > 2.2.2.2.3389: P 457295121:457295657(536) ack 3592134313 win 64860
At packet 521, suddently the server sent RESET packet to the user to terminate the connection
521: 10:06:36.894591 2.2.2.2.3389 > 1.1.1.1.5555: R 3592134313:3592134313(0) ack 457295657 win 64860
Packet 522-524, client try to re-establish the connection
 522: 10:06:36.919630 1.1.1.1.6666 > 2.2.2.2.3389: S 2294133377:2294133377(0) win 64512 <[|tcp]>
523: 10:06:36.920484 2.2.2.2.3389 > 1.1.1.1.6666: S 2704546546:2704546546(0) ack 2294133378 win 16384 <[|tcp]>
524: 10:06:36.920667 1.1.1.1.6666 > 2.2.2.2.3389: . ack 2704546547 win 64860
And communication re-created again..
 525: 10:06:36.920805 1.1.1.1.6666 > 2.2.2.2.3389: P 2294133378:2294133416(38) ack 2704546547 win 64860
526: 10:06:36.922376 2.2.2.2.3389 > 1.1.1.1.6666: P 2704546547:2704546558(11) ack 2294133416 win 65497
527: 10:06:36.922636 1.1.1.1.6666 > 2.2.2.2.3389: P 2294133416:2294133828(412) ack 2704546558 win 64849
528: 10:06:36.923978 2.2.2.2.3389 > 1.1.1.1.6666: P 2704546558:2704546895(337) ack 2294133828 win 65085
529: 10:06:36.924207 1.1.1.1.6666 > 2.2.2.2.3389: P 2294133828:2294133840(12) ack 2704546895 win 64512
530: 10:06:36.924253 1.1.1.1.6666 > 2.2.2.2.3389: P 2294133840:2294133848(8) ack 2704546895 win 64512
531: 10:06:36.924955 2.2.2.2.3389 > 1.1.1.1.6666: . ack 2294133848 win 65065
And die again....
I don't understand why the server keep sending RESET packet to the client?
Marcin Latosiewicz Mon, 06/14/2010 - 02:24
Morning,
Can you please confrim for me rather the ASA version and where the capture was taken ? (outside or inside of the ASA?)
Please also rememebr that you can extract the captures in pcap so you can open them in wireshark !
from cli (copy /pcap capture ...)
from https  Https://Ip.address/capture/CAPTURE_NAME_HERE/pcap
Please note - this is a retranmission.
Followed by reset:
To get ot the bottom of things - you'd need to get a capture on both inside and outside interfaces.
Adam David Mon, 06/14/2010 - 03:16
Thanks Marcin for the tips on wireshark.
Hardware: ASA5520,
Software Version 8.0(4)32
Yeah, I notice that. The retransmission started at packet 511 to 520 before the server sent the RST packet.
I've captured both inside and outside interface. The only RST packet that I can see is in inside interface.
Here are the commands that I use to capture the network packet.
Access list to filter both source & destination
access-list cap extended permit tcp host 1.1.1.1 host 2.2.2.2
access-list cap extended permit tcp host 2.2.2.2 host 1.1.1.1
Capture both inside & outside interface
capture cap access-list cap interface inside packet-length 54
capture cap-out access-list cap interface outside packet-length 54
View capture
show capture cap-in
show capture cap-out
Let me know if you need more information.
Marcin Latosiewicz Mon, 06/14/2010 - 03:42
I understand you don't want to share the pcap based capture for security reasons?
Can you maybe then attach text based capture the full lenght - I'm not sure what I will be able to dig out.
Did you by any chance also try type asp capture?
capture asp type asp all
Will give you information about packet drops on ASA because of security checks ...
larrylewis Mon, 06/14/2010 - 14:02
I'm running into the same issue with a recent setup on an ASA 5505 running 8.0(5). I'm seeing the same behavior with a handshake, repeated push from the client and then a reset from client. Trying to initiate another rdp connection shows syns from client but no ack from server. clearing the arp cache helps temporarily but the problem returns after a short time.
