Creating a music folder on 4305g DMP
Answered Question
May 31st, 2010
Hi Tomas,
We have just upgraded one of our 4305g DMPs from version 5.1 to version 5.2. I would like to test an .mp3 music file.  In a previous post, you gave me the following instructions:
"Using version 5.2 on a DMP-4400G, I simply used an FTP client and copied the
music.mp3 file to the DMP and placed into
the (self created) music directory.
Once the file is copied successfully, I entered
the following URL in the DISPLAY ACTIONS-->MEDIA URL
file:///tmp/ftproot/usb_1/music/music.mp3
Click START and the music plays successfully."
Can you please tell me which user id you used to create the music folder as I have tried using the Web account and was presented with 'insufficient access privileges'?
I also tried using:
  • my user id that I use to log into the DMM AAI as I'm set up as an administrator
  • superuser
with all attempts, I get 'access denied'.
I tried using PuTTy and WinSCP (FTP clients).
Thank you
Cheers
Linda
Correct Answer by Tomas De Leon about 6 years 7 months ago
By Flash, I mean Compact Flash which is the INTERNAL STORAGE settings...
If we got everything working, please mark this thread as ANSWERED and RATE the
responses.
T.
Overall Rating: 5 (1 ratings)
Tomas De Leon Tue, 06/01/2010 - 08:46
A couple of things:
After the upgrade, you need to check (from the DMP-DM)
* under Management Services - is FTP Server ON?
* under Internal storage - Is Access mode "Read and Write"
the FTP user is defined under "DMP Service Account" on the DMP-DM.
This is the user that you will use.
Check these..  if you make any changes, Apply, Save, and reboot DMP.
Then Try again...
T.
lindam005 Tue, 06/01/2010 - 15:22
Hi Tomas,
I have check all three attributes and all three are there.  I still can't create a folder.
* under Management Services - is FTP Server ON?  Yes
* under Internal storage - Is Access mode "Read and Write"  Yes
the FTP user is defined under "DMP Service Account" on the DMP-DM.  Yes.
Is there anything else that I can check?
Thank you
Cheers
Linda
Tomas De Leon Wed, 06/02/2010 - 17:32
Linda,
Please try the following:
* use the "reset" button on back of DMP to restore the factory defaults
* then access the DMP via the DMP-DM and reconfigure "all" of the settings.
  Apply, Save, and Restart DMP.
* Test making directory using a FTP client like "Filezilla"
* Also after doing this please provide a screen shot of the Hardware\Firmware version of the DMP from
the DMP-DM
Cheers!
T.
Tomas De Leon Wed, 06/02/2010 - 18:24
Linda,
from
the DMP-DM
Cheers!
T.
lindam005 Wed, 06/02/2010 - 18:57
Hi Tomas,
We are currently still running on version 5.1 but have upgraded one each 4305g and 4400g to version 5.2.  I tried creating the folder on the 4305g that was upgraded to test .mp3 playing.  The DMM is still running version 5.1.
I tried creating a folder on 4305g version 5.1 and it worked successfully.
I'm thinking that it could be something to do with the upgrade but will investigate further.  If I reset the DMP back to factory settings, it will revert back to version 5.1.  I'll try in a few days time and let you know how I go.
Thank you.
Cheers
Linda
Tomas De Leon Wed, 06/02/2010 - 22:30
If the DMP is running version 5.2, Resetting to factory defaults only changes
the configuration not the software version.   Please provide a snapshot of
the Software\Hardware version of of a DMP you believe to be running 5.2.
T.
lindam005 Mon, 06/07/2010 - 16:26
Hi Tomas,
Since resetting to default factory settings, I cannot reach the DMP any more via the browser or any FTP apps.   Although the DMP is connected to the network, in trying to access it, I get 'Cannot be found' error.
Pinging the DMP also responds with 'Request timed out'.
The DMM is still on version 5.1 however does show the DMP to be on version 5.2 although it has a red cross next to it.
Thank you
Cheers
Linda
Tomas De Leon Tue, 06/08/2010 - 06:15
Linda,
The DMM will not be able to talk to the DMP correctly
since they are on "Different" versions.  Remember, the DMPs and
the DMM MUST be on the same versions to function correctly.
The DMP(s) on 5.2 (while your DMM is 5.1) will basically be
"standalone" DMPs.
In regards to the access issue,  after resetting the DMP to factory defaults
the DMP's config should be empty.  That said you will need to watch the
display as it boots up to see it's IP address. the address MAY change and
that could be your connectivity issue.
* Verify the DMP IP address on the Screen
* Verify the GREEN light is on, on the front of the DMP (NOT red)
Once you verified the IP address, please try accessing again...
Let me know..
T.
lindam005 Mon, 06/14/2010 - 18:57
Hi Tomas,
I understand the DMM (version 5.1) cannot talk to the DMP (version 5.2) because they are both on different versions, I took the screen shot to show you the DMP was version 5.2.
I finally have the DMP up and running after restoring to factory settings.
Using WinSCP3, I could log onto the DMP using the DMP Service account (ftp) and could create a folder under the /usb_1 directory.
I copied an mp3 file into the music folder but when the copy completed a warning message (please see attachment) was displayed.  When I attempted to play the music via browser Play Media File Stored Locally option, I don't get any sound.
I have since tried to copy the file to various directories including file:///usb_1/deployment/xTAS-core/api/xml/app/playlist/ without success.
I think it has something to do with the copying error. Any ideas or suggestions?
Cheers
Linda
Tomas De Leon Tue, 06/15/2010 - 06:57
Linda,
Can you please repeat test of making directory using a FTP client like "Filezilla".
I have not seen the error that you provided but it appears that winscp is setting
or trying to set permissions.  I use Filezilla without any issues.
Also, since you got the DMP to reset to factory defaults make sure that the
"Flash" is set to READ\WRITE.
Let me know the results of the filezilla tests..
T.
lindam005 Tue, 06/15/2010 - 18:39
Hi Tomas,
Found my issue, when I added the URL to play locally, I was omitting /tmp/ftproot from the URL so instead of entering: file:///tmp/ftproot/usb_1/music/Maria.mp3 I was typing in file:///usb_1/music/Maria.mp3
I was able to create the directory and copy the music file into the directory using WinSCP3 and although I got the error as in previous e-mail, the music did actually play once I entered the correct URL.
You also mention to ensure 'Flash' was set to read/write, I couldn't find the 'Flash' option.  Can you please tell me where is the option?
Thank you very much for your assistance.
Cheers
Linda
Correct Answer
Tomas De Leon Tue, 06/15/2010 - 19:32
responses.
T.
lindam005 Tue, 06/15/2010 - 20:48
Hi Tomas,
I see the 'Flash' option in Internal Storage as 'Access Mode' and yes, I had already set that to 'Read/Write'.
All good now thanks to you and your support.
Cheers
Linda
Related Content
