Material for gateways/trunk voip.
May 31st, 2010
Hi all experts.
I am new to voip and as i am going through Cvoice, i like to practice material that is given there. Like working with FXS/FXO, E1 cards, setting up trunks etc. I can surely use cisco command reference, but for a starter i would like to use some sort of workbook. Can someone share his/her experience about any material they have covered and feel satisfied regarding the configuration examples ? like setting up T-CCS, MGCP trunks, SIP trunks, and stuff like that. I have seen workbooks covering CME/CUE/ CUCM, and other applications in great depth but i am not able to find any material regarding sole IOS configurations of trunks and interface and different scenarios.
Anyone ?
Overall Rating: 5 (2 ratings)
Walter Solano Tue, 06/01/2010 - 05:18
Hello Jon,
I don't know if there is any workbook specific for gateways, my recommendation will be to setup a cool lab on your own or  if you already cover the CUCM part you could try with IP experts or any of the workbooks that are available for the CCIE-V.
Please rate this post if was helpful
Walter Solano
CCNA Voice
Cisco UCCX Specialist
rob.huffman Fri, 06/04/2010 - 06:21
Hi Jon,
Just to add a touch to the good info from my friend Walter (+5 "W")
This is an excellent guide
Attached is a file from  Jorge @  AT&T .
Hope   this helps!
Rob
Adrian Saavedra Wed, 06/09/2010 - 22:48
Rob -- that's a nice PDF document (5 stars).
Jon -- I don't know if you've read the books I mention below. Both provide information about the topics you're searching, configuration examples with figures and case studies. Both books will be of great help (along with the PDF) if you also have in mind getting a CCVP certification. You can give a try:
Cisco Voice Gateways and Gatekeepers
http://www.ciscopress.com/bookstore/product.asp?isbn=158705258X
Cisco Voice over IP (CVOICE) (Authorized Self-Study Guide), 3rd Edition
http://www.ciscopress.com/bookstore/product.asp?isbn=1587055546
Hope it helps.
Kind regards,
-- Adrián.
