LMS 3.2 - LMS Portal -- How to set 'My Portal' View as Default-View?
Answered Question
May 31st, 2010
Hi all,
LMS Portal comes up with three default views (My Portal, CiscoWorks Portal, LMS).
As within My Portal it is possible to change layout and sorting, I would like to set this view as
the default view comming up at login.
How can this be configured?
Actually LMS View comes up.
Thanks for any feedback
Correct Answer by Michel Hegeraat about 6 years 9 months ago
You have to add the portlet Ciscoworks Admin to your portal
With this portlet you can set the default view
Add portlet -> Ciscoworks -> Other -> Ciscoworks Admin
Cheers,
Michel
Overall Rating: 5 (1 ratings)
Correct Answer
Michel Hegeraat Tue, 06/01/2010 - 06:10
  • Gold, 750 points or more
Cheers,
Michel
lo.mueller Wed, 06/02/2010 - 00:03
Hi Michel,
thanks a lot for your input, this helped a lot.
Best Regards
Lothar
