How to create a "hunt group" in SRST configs?
Jun 1st, 2010
I'm curious how this would be done.  The scenario is that I have a branch office with approx. 50 people.  In the event of circuit failure, I would like to configure the SRST to ring a specific order of phones through my FXO ports - let's just say ten for discussion's sake.  Is this as simple as the following?
default-destination XXXX
alias 1 XXXX to 1111
alias 2 XXXX to 1112
alias 3 XXXX to 1113... and so on through alias 10
If not, how would I achieve the above requirement?
Thanks for the help...
ajrussell Tue, 06/01/2010 - 09:00
I suppose it would be useful to see the rest of the SRST config already on the router:
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 6
ip source-address 10.1.1.1 port 2000
max-ephones 50
max-dn 192
system message primary Primary Link Down
system message secondary Primary Link Down
transfer-pattern ....
voicemail 93039871111
moh BeStillMyLove.ulaw.wav
multicast moh 239.1.1.1 port 16384 route 10.1.1.1 10.1.50.1
time-zone 6
Would adding the previously mentioned alias commands provide the functionality I'm after?
Jaime Valencia Tue, 06/01/2010 - 11:37
With just SRST you cannot, you need CME-as-SRST for this.
SRST Fallback Mode Using Cisco Unified CME
This feature enables routers to provide call-handling support for  Cisco Unified IP phones if they lose connection to remote primary,  secondary, or tertiary Cisco Unified Communications Manager  installations or if the WAN connection is down. When Cisco Unified SRST  functionality is provided by Cisco Unified CME, provisioning of phones  is automatic and most Cisco Unified CME features are available to the  phones during periods of fallback, including hunt-groups, call park and  access to Cisco Unity voice messaging services using SCCP protocol. The  benefit is that Cisco Unified Communications Manager users will gain  access to more features during fallback without any additional licensing  costs.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesrst.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Joel Hatfield Tue, 06/01/2010 - 18:36
Are you using a PLAR on the FXO port for inbound calls?  If all you are looking to do is ring the phones you list in the  specific order then try this:
no huntstop
alias 1 XXXX to 1111 preference 1
alias 2  XXXX to 1112 preference 2
alias 3 XXXX to 1113 preference 3... and so on through alias 10
ajrussell Wed, 06/02/2010 - 10:32
Thanks, Joel - I believe that is exactly what I need.  Appreciate the help...
