Line Description with CCM7
Jun 1st, 2010
How to display the Line description in a CCM7?
I want that it display the name of the user il the same line as the date.
In CCME, It is called Line Description.
I've configured it in the Line configuration but, It doesn-t show the Line.
Best regards
Overall Rating: 5 (2 ratings)
iantra123 Tue, 06/01/2010 - 07:22
Thank You,
But This option cannot be used for displaying names.
I want that a Name will appear there, not the E164 number folowed by the extension.
rob.huffman Tue, 06/01/2010 - 07:33
Hi Iantra,
My apologies my friend
I didn't read your first post correctly, you are correct
that only Numbers can be displayed on the Top line of
the IP Phone display with CUCM. You can use the "Line Text"
config (under DN config page) to display the users name next
to their Directory Number but this will not be on the "Top" of
the phone display.
