3750 with integrated wireless controller , port-channel want came up
Jun 1st, 2010
We had WS-C3750G-24WS-S25 running for a long time already (about 6 month).
After power failure switch was came up as long as a wireless controller (I can successfully access both of them via console) , however Port-Channel still in down state.
Is there any CLI commands you can advise I can run on controller to check port/portchannel configuration from controller side ?
I attached various show commands, and any of your advices will be greatly appreciated.
GigabitEthernet1/0/27  unassigned      YES unset  down                  down
GigabitEthernet1/0/28  unassigned      YES unset  down                  down
Port-channel40         unassigned      YES unset  down                  down
SWCM_api.c 1976: In call to 'SWCM_register_access()', error: bad args
Jun 01 13:50:19.640 dtl_net.c:602 DTL-3-ARP_SEND_FAILED: Could not send ARP requ
est to 00:1b:53:63:db:07. VLAN=200, Intf=29. pdu transmit error.
- Traceback:  1029f970 103f32dc 10291718 103d409c 10b955a8 10d4ec6c
Jun 01 13:50:19.640 dtl_pdu_landd.c:452 DTL-3-PKT_TX_ERROR: Failed to transmit a
packet of type 0,USP:0/3/1.
- Traceback:  102a50c8 1029f8fc 103f32dc 10291718 103d409c 10b955a8 10d4ec6c
Jun 01 13:50:19.640 sysapi.c:160 SYSTEM-3-SYSAPI_ERR: System Error : dapi.c 1466
: In dapiCtlLagIntf() Frame sent to Lag that does not exist
Jun 01 13:50:19.640 sim.c:784 SIM-3-ARP_SND_FAIL: Unable to send ARP Request. Lo
cal MAC: 00:1B:53:63:DB:00.Ip Addr: 10.0.200.3Interface # 29. Vlan Id: 200
est to 00:1b:53:63:db:00. VLAN=200, Intf=29. pdu transmit error.
- Traceback:  1029f970 103f2d74 102916dc 103d409c 10b955a8 10d4ec6c
- Traceback:  102a50c8 1029f8fc 103f2d74 102916dc 103d409c 10b955a8 10d4ec6c
Jun 01 13:50:19.639 sysapi.c:160 SYSTEM-3-SYSAPI_ERR: System Error : dapi.c 1466
Jun 01 13:50:18.790 sntp_main.c:274 SNTP-3-FATAL_ERROR_OCCURED: Fatal error: : u
nable to send NTP packet.
Jun 01 13:50:16.790 sntp_main.c:274 SNTP-3-FATAL_ERROR_OCCURED: Fatal error: : u
Burned-in MAC Address............................ 00:1B:53:63:DB:00
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: WS-C3750G-24WS-S25,  VID: V01,  SN: FOC1117G01F
Load for five secs: 6%/1%; one minute: 6%; five minutes: 6%
Time source is NTP, 09:51:14.861 EST Tue Jun 1 2010
Wireless Controller in Switch 1
Operational Status of the Controller : wait_for_init
Service VLAN                         : 4095
Service Port Mac Address             : ffff.ffff.ffff
Service IP Address                   : 127.0.1.1
Management IP Address                : 0.0.0.0
Management VLAN                      : 0
Software Version                     : unknown
Keepalive Version(controller/switch) : 0/1
Keepalives Missed                    : 0
Controller accepts http/https        : 0/0
Controller's Status Line             : up
Watchdog resets of Controller        : 0
Controller resets total              : 1
Unacknowledged control messages      : 1
Overall Rating: 5 (1 ratings)
dancampb Tue, 06/01/2010 - 07:46
  • Cisco Employee,
"'SWCM_register_access()',  error: bad args" often is related to a hardware issue.  Are you able to session into the controller?  If so are the ports showing up?
Andriy Yerofyeyev Tue, 06/01/2010 - 07:59
Thanks for reply,
Yes , I am able to session to controller.
(Cisco Controller) >show port summary
           STP   Admin   Physical   Physical   Link   Link    Mcast
Pr  Type   Stat   Mode     Mode      Status   Status  Trap   Appliance   POE
807398816 Normal  Disa Enable  10 Full    10 Full    Down   Enable  Enable     N
/A
Related Content
