06-01-2010 08:36 AM
The WAAS lock, had no access via telnet and console.
As the WAAS solution is reset
any ideas
Gregorio
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2009 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.1.3 (build b55 Apr 18 2009)
Version: oe674-4.1.3.55
Compiled 00:13:45 Apr 18 2009 by cnbuild
CPU 0 is GenuineIntel Intel(R) Xeon(R) CPU E5335 @ 2.00GHz (rev 15) running at 1995MHz.
CPU 1 is GenuineIntel Intel(R) Xeon(R) CPU E5335 @ 2.00GHz (rev 15) running at 1995MHz.
CPU 2 is GenuineIntel Intel(R) Xeon(R) CPU E5335 @ 2.00GHz (rev 15) running at 1995MHz.
CPU 3 is GenuineIntel Intel(R) Xeon(R) CPU E5335 @ 2.00GHz (rev 15) running at 1995MHz.
Total 4 CPUs.
4096 Mbytes of Physical memory.
128 MBytes of flash memory
1 CD ROM drive (Vendor MATSHITA Model UJDA780 DVD/CDRW)
2 GigabitEthernet interfaces
2 InlineGroup interfaces.
1 Console interface
Manufactured As: WAE-674-K9 [7979P5A]
Log
2010 May 23 21:21:17 WAE-Renca1 httpmuxd: %WAAS-HTTPAO-4-131001: (641149) worker pool isn't healthy
2010 May 31 17:10:28 (none) populate_ds: %WAAS-CLI-5-170050: Cisco WAAS software starts booting
2010 May 31 17:10:28 (none) create_etc_hosts.sh: %WAAS-CLI-5-170051: HOSTPLUSDOMAIN: NO-HOSTNAME
2010 May 31 17:10:28 (none) ver_hostname: %WAAS-CLI-5-170053: Recreated etc_hosts (1, 0)
2010 May 31 17:10:29 NO-HOSTNAME Nodemgr: %WAAS-NODEMGR-5-330082: [CLI_VER_NTP] requests stop service ntpd.
2010 May 31 17:10:29 NO-HOSTNAME ftp_export: %WAAS-UNKNOWN-2-899999: sysdb_item_get failed for /cfg/gl/wmt/trans_log/export/enable: 4
2010 May 31 17:10:29 NO-HOSTNAME ftp_export: %WAAS-UNKNOWN-2-899999: exiting at ftp_export.c:1012
2010 May 31 17:10:32 NO-HOSTNAME Nodemgr: %WAAS-NODEMGR-5-330080: [Nodemgr_Admin] requests start service videoao
2010 May 31 17:10:32 NO-HOSTNAME ver_ao_common: %WAAS-CLI-5-170053: sucessful nodemgr start videoao request
2010 May 31 17:10:33 NO-HOSTNAME Nodemgr: %WAAS-NODEMGR-5-330080: [Nodemgr_Admin] requests start service httpao
2010 May 31 17:10:33 NO-HOSTNAME ver_ao_common: %WAAS-CLI-5-170053: sucessful nodemgr start httpao request
2010 May 31 17:10:34 NO-HOSTNAME Nodemgr: %WAAS-NODEMGR-5-330080: [Nodemgr_Admin] requests start service cifsao
2010 May 31 17:10:34 NO-HOSTNAME ver_ao_common: %WAAS-CLI-5-170053: sucessful nodemgr start cifsao request
2010 May 31 17:10:35 NO-HOSTNAME Nodemgr: %WAAS-NODEMGR-5-330080: [Nodemgr_Admin] requests start service mapiao
06-01-2010 01:22 PM
Can you provide a full system report from this device?
Zach
06-01-2010 01:55 PM
hi,
attached sysreport
regards,
Gregorio.
El mensaje fue editado por: Gregorio Ignacio Farias Pinto
06-01-2010 02:28 PM
second file
06-07-2010 01:59 PM
Hi Gregorio,
Looking through the sysreport it appears that there is an issue with resource starvarion (perhaps memory) on the WAE. We can do a couple of things here:
1. Upgrade to latest 4.1(7) release and see if the problem reoccurs. This will ensure that we are running with all of the latest bug fixes. The downside is that if the problem doesn't reoccur, we may not be able to come to a 100% root cause.
-- or --
2. We can try to debug the issue on the current 4.1(3) version. This will require some assistance from you to run some scripts, wait for the issue to occur again, then collect and provide some information to us for analysis. The downside is that you are pretty much guaranteed to have additional service outages. The upside is that we are more likely to get to a definitive root cause.
I'll leave the choice up to you. Let me know how you would like to proceed.
Zach
01-09-2012 05:29 AM
Hi Zach,
I am seeing something similar to this in a solution that we have deployed. Its a very busy office with 2 x 7341 devices. Unfortunately we are running WCCP from 7204 routers and using hash as assignment mechanism:
KM-UKLEE-WAE-0G02 java: %WAAS-CIFSAO-4-131001: (169653) worker pool isn't healthy
What does this refer to ?? Does it required TAC assistance do you think ??
Paul
01-09-2012 08:42 AM - last edited on 02-01-2024 06:53 AM by Gabriela Godoi do Prado
Hi Paul,
What is the WAAS version they are running?
Zach Seils, CCIE #7861
01-10-2012 12:32 AM
Hi Zach,
We are running 4.1.5f - - - We are looking to upgrade in the near future……
Rgds,
Paul
Paul Wilcock | 21C Customer Edge Platform Team - Ethernet Technologies | BT Design & Innovate | Tel:+44 (0)1277 326664 | E: paul.wilcock@bt.com | www.bt.com<>>
01-10-2012 06:13 AM
I would suggest we engage TAC to further troubleshoot this issue.
Zach
