Configuring Multiple SSIDs
Jun 1st, 2010
I like to run multiple SSIDs on the same terminal. As the dynamic assignment of VLANs does not work with MBSSID, I try to configure how SSIDL IE. I followed the doc Cisco (Chapter 7) Next, alas my config does not work (in fact, among the clients tested, only one client receives the correct SSID). I upgraded the terminal IOS 12.4 (21a)-JA1 without success. Thank you for your help.
you can find in the attach the configuration.
Could you please help me ?
Best regards
Scott Fella Tue, 06/01/2010 - 12:45
You have alot of vlans and ssid's.. might cause you issue with older clients or handheld devices.  You check your radius logs to see what the failure are.  Make sure you set the radius attributes correct:
The RADIUS user attributes used for the VLAN ID assignment are:
  • IETF 64 (Tunnel Type)—Set this to VLAN.
  • IETF 65 (Tunnel Medium Type)—Set this to 802
  • IETF 81 (Tunnel Private Group ID)—Set this to VLAN ID.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
