seanbdavis Thu, 08/19/2010 - 13:00
Hope it will be soon I am doing a UCM in London in
three weeks!
Aaron Harrison Fri, 08/20/2010 - 00:33
  • Community Spotlight Award,
    Member's Choice, May 2015
The v7.x dial plans in the readme say 'for 7.x and later'. Try installing that.
Aaron
Please rate helpful posts...
markdoney1 Fri, 08/20/2010 - 01:31
You cant install a CUCM 7 dial plan on CUCM 8, but you can upgrade from a dialplan on 6 or 7 to CUCM 8 and the dial plan will stil work.
Aaron Harrison Fri, 08/20/2010 - 04:08
You sure? I had a look at the install script and it looks like it just doesn't like v5/6:
CUCM_MASTER=`echo $CUCM_VERSION | cut -c1-8`
if [ $CUCM_MASTER == "master-5" ]||[ $CUCM_MASTER == "master-6" ]
then
echo CHECK CALL MANAGER VERSION - COPFILE MEANT ONLY FOR CUCM 7.x AND ABOVE
exit 1
fi
Like I say, I've not got round to trying it..
Aaron Harrison Tue, 08/24/2010 - 02:53
I've just installed the GB 3-1-15 dial plan for 'CM 7.x and later' on my 8.0(2) lab system to verify this. No problem...
Aaron
