6500 TCAM usage for MPLS
Jun 1st, 2010
Hello!
I'm using cat6500 WS-SUP720-3BXL as BGP router for 3 full view upstream an several clients. Different clients want to use different upstream for output traffic, but output should be redundant . So I should implement VRF + BGP.
I have done the following config:
ip vrf Upsream1
rd Y:Z
     import map Bacup1-rmap
route-target export Y:Z
route-target import N:M
ip vrf Upsream2
rd N:M
import map Bacup2-rmap
route-target import Y:Z
route-target export N:M
router bgp XXX
  address-family ipv4 vrf Upsream1
  neighbor Y.Y.Y.Y remote-as ZZZ
  neighbor description  GoodUplink
  address-family ipv4 vrf Upsream2
  neighbor N.N.N.N remote-as MMM
  neighbor description  BadUplink
after loading full view in to table I get error
MLSCEF-SP-7-FIB_EXCEPTION: FIB TCAM exception, Some entries will be
software switched
#show platform hardware capacity forwarding
L3 Forwarding Resources
FIB TCAM usage:                     Total        Used       %Used
72 bits (IPv4, MPLS, EoM)     1032192      1002192         95%
144 bits (IP mcast, IPv6)        8192           8          1%
detail:      Protocol                    Used       %Used
IPv4                      600035         64%
MPLS                       32992          31%
Command
#show mpls forwarding-table
show all routes with label.
Question: is can I some how use VRF+BGP but disable TCAM MPLS table usage, and label generation  for my platform?
Cisco say
Ipv4 routes ---1 TCAM entry
ipv4 routes(vpn/vrf) -- 1 TCAM entry
ipv4 multicast -- 2 TCAM entry
ipv6 (anycast/unicast) -- 2 TCAM entry
MPLS labels --  1 TCAM entry
But look like BGP+VRF =2 TCAM entry.
Is there any workaround to use 1 TCAM entry for one route in VRF from BGP for 6500?
Thank you for answer!
Giuseppe Larosa Wed, 06/02/2010 - 10:34
  • Hall of Fame,
    Founding Member
Hello Sergiy,
if you are using MPLS L3 VPN you need MPLS labels only for the loopbacks or remote PE nodes.
if you are doing VRF lite you actually don't need any label.
An attempt to reduce MPLS forwarding table size can be done by using a filter to be applied to LDP
so you start from
mpls ip
you add
access-list 11 permit 10.80.0.0 0.0.255.255
no mpls advertise-label
mpls advertise-label for 11
you need to do this on all PE nodes for consistency this may reduce the MPLS forwarding table size.
Hope to help
Giuseppe
Laurent Aubert Fri, 06/04/2010 - 06:26
  • Cisco Employee,
You can't disable TCAM utilisation as this is what allows traffic swithing in hw. But they have limited number of entries (1M in your case) so when the TCAM is full, new entry can't be programmed and will be switch in software impacting the CPU.
Do you really need the full routing table in several VRF ? it's not a recommanded design. If you need to bind a customer with an upstream SP, a default route received from each SP is enough. Each upstream VRF export it with different RT and on customer vrf, you import two of them for redundancy.
Laurent.
belovell Fri, 06/04/2010 - 09:12
Agreed.
To be clear, vpnv4 routes will use two TCAM entries irrelvant to whether it's VRF lite or MPLS L3 VPN.
1 ipv4 route = 1 TCAM entry from ipv4 space.
1 vpnv4 route = 1 TCAM entry from ipv4 space + 1 entry from MPLS space. So two entries total.
You can reallocate your 1M TCAM entries so that approx 512K are ipv4 and 512K are MPLS(leave a little for other things) and then you have can ~500K vpnv4 routes but as Laaubert indicated this is not a great way to go about things.
-Ben
Sergiy Pyvovaroff Mon, 06/07/2010 - 03:53
Hello! thanks for the tips. I found on the same forum an interesting solution of the problem.
MPLS VPN—Per VRF Label
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_vpn_per_vrf_lbl.html
With this tecnology ony one mpls lable used by one VRF:
But it requires inclusion of beta-future in the network core.
Who can tell how stable this feature  and whether it will be realised?
Today I decided to use two technologies that have already passed the test of time.
The first
BGP Support for IP Prefix Import from Global Table into a VRF Table
No MPLS LABEL for route from Global.
http://www.cisco.com/en/US/docs/ios/12_2s/feature/guide/fs_bgivt.html
Multi-VRF Selection Using Policy Based Routing (PBR)
And http://www.cisco.com/en/US/docs/ios/12_2sr/12_2srb/feature/guide/srb2mvrf.html
Sergiy A. Pyvovaroff
belovell Mon, 06/07/2010 - 06:59
Per VRF label will not change anything about TCAM usage. This is why I made the point that it does not matter if the route is vpnv4 or vrf-lite. Any time a route(label or not) is in a VRF routing table on the 6500 is will use extra TCAM entries.
-Ben
Related Content
