cucm 7.1 AD Change
Jun 1st, 2010
Do you know of any "Reconfiguration and Upgrade Guides" for CUCM 7.X that explains the process of pointing the Pub and Sub to a new domain? I have searched and so far I have not found anything explaining a step process for this task.
Thanks in Advance!
Overall Rating: 5 (1 ratings)
David Hailey Tue, 06/01/2010 - 14:51
  • Purple, 4500 points or more
This is handled via the LDAP System Configuration (you can only choose one type of directory - e.g., AD) and first enabling sync.  Then you need to change the LDAP Directory and LDAP Authentication configurations for the new AD integration.  I believe you can only integrate with a single AD domain; however, you can configure up to 5 separate agreements (DirSync / LDAP Directories) to customize the scope of the search (i.e., configuration of specific OU's within the AD domain).  2 resources to look at are:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html
http://blog.ipexpert.com/2010/04/28/cucm-and-active-directory-integration/
Hailey
Please rate helpful posts!
Related Content
