Using LCD-100-Pro-40N as an external display
Answered Question
Jun 1st, 2010
Hello. I'm installing CTS1300 and using LCD-100-Pro-40N as an external display.
When I previously use third party LCD(NEC LCD), I used DVI to HDMI cable between TelePresence and external display.
Does LCD-100-Pro-40N also need DVI to HDMI cable? Or is HDMI to HDMI cable available since both are Cisco brand?
Correct Answer by harshdaftary about 6 years 9 months ago
Both cables can work but Cisco recommend DVI-HDMI cable between codec and an external display.
Cheers,
Harsh
Overall Rating: 5 (1 ratings)
Correct Answer
harshdaftary Wed, 06/02/2010 - 02:17
Cheers,
Harsh
t.takemoto Wed, 06/02/2010 - 08:51
Thanks for your advice.
I confirmed that HDMI-HDMI works.
For your information, when I installed a NEC LCD, HDMI-HDMI didn't work. HDMI-DVI was the right cable.
