06-01-2010 09:47 AM - edited 03-19-2019 01:01 AM
I am running Unity 7.1. We are moving our systems from Novell to Windows Server 2008. I need to merge the Unity active directory with the new Active directory that has been set up for the network. Can anyone help me with that procedure? Do's, Don'ts, etc. Thanks.
06-02-2010 07:58 AM
Brent,
Are you looking more for what to do on the Microsoft (AD) side of the house or rather what you need to do to reconcile Unity accounts and settings after the new AD environment is built out?
Hailey
Please rate helpful posts!
06-02-2010 09:05 AM
We have the AD in Unity and are building an AD for the district. What is the best course of action? Try to push the Unity AD to the new domain or try to merge them once the new domain is active?
Brent
06-02-2010 02:16 PM
Well, for the AD side of it - it would depend on what you are most comfortable with doing. How I would do it may not be how you would do it...personally, I am a fan of clean rebuilds as you don't often get the opportunity to do that sort of thing very often.
As far as Unity is concerned, swapping domains takes a bit of planning and work as well. Have you looked at those procedures yet? If not, I can send over some links to you and we can discuss further from there.
Hailey
06-03-2010 07:54 AM
I have not looked at the documentation for the procedures for that implementation. We were going to just let them run seperately, but it is looking like we are going to have to integrate them because we are going to use Novell's Identity Manager.
