unable to Ping switch
Answered Question
Jun 1st, 2010
Hi Experts
I have a cisco 3560 Switch.
interface 1 & 2 are uplink ports for data and voice vlan respectively
int 3 to 24 are access ports
i have switch ip address on vlan1 which has port 28 in it
How to : ping the ip address of the switch.
Any suggestions
AK
Correct Answer by Ganesh Hariharan about 6 years 11 months ago
Hi Experts
Any suggestions
AK
Hi AK,
To ping the ip address of the switch you need to have desktop in same vlan that is vlan 1 and as Reza pointed out SVI for vlan 1 should be configured .Then you can ping the switch ip address and as 3560 is l3 switch if ip routing is enabled then other vlan member can also ping the switch ip address.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Reza Sharifi Tue, 06/01/2010 - 10:49
  • Cisco Designated VIP,
    2017 LAN
Hi Asif,
If I understand you correctly, you are trying to ping the IP address for VLAN 1.  Do you already have svi configured with ip address?  If yes you can just plug your pc to port 28 and give it an ip address in the same range as the switch  You should be able to ping the IP of the switch now.
Reza
akhanwaterloo Tue, 06/01/2010 - 10:57
yes switch has an ip address in vlan 1 which i would like to access remotely in this i have to be on the site to connect to it.
Asif
Ganesh Hariharan Tue, 06/01/2010 - 11:11
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Asif
Asif,
Is the switch ip is routable in your network, if yes then you can access remotely if not then you need to be onsite to access.
Hope to Help !!
Ganesh.H
Correct Answer
Ganesh Hariharan Tue, 06/01/2010 - 10:53
Hi Experts
Any suggestions
AK
Hi AK,
Hope to Help !!
Ganesh.H
