WAAS RDP Optimization
Answered Question
Jun 1st, 2010
Has anybody been able to see any optization on Microsoft RDP (Port 3389)?.
Is RDP traffic compressed/encrypted?.
Any support appreciated.
Cheers,
Dinesh
Correct Answer by Eric Rose about 6 years 9 months ago
Hi Dinesh,
Here is a document that talks about the process.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns224/ns377/deployment_guide_c07-493981.html#wp9000716
also when you "optimize" compressed data the output is actually more (larger) data.
so when you see the optimize traffic is more than the originial traffic, this is a sign that the original traffic is already compressed or encrypted.
for example when you compress a jpg the result is larger.
Eric
P.S. please mark this question as answered with a 5 if this answers your question.
Overall Rating: 5 (1 ratings)
Eric Rose Tue, 06/01/2010 - 11:15
  • Cisco Employee,
Yes I have seen huge saving when the default encryption and compression was disables for the MS RDP protocols on port 3389.
Eric
dinesh.thathana... Wed, 06/02/2010 - 04:14
Thanks Eric, Jan.
Can someone tell me how do I disable compression/encryption for RDP on the client side?
Additionally my CM Optimzation suggests that my original traffic was 10GB excluding passthrough and the optimized traffic is close to 11GB. Did anyone see such kind of data where optimized data is more than original?
-Dinesh
Correct Answer
Eric Rose Wed, 06/02/2010 - 07:24
  • Cisco Employee,
Hi Dinesh,
Eric
dinesh.thathana... Thu, 06/03/2010 - 04:37
Thanks ERIC.
To summarize if I do the following things, will RDP be optimized on a WinXP machine?
1. Disabling Compression on the RDP File
                Step 1. Open the RDP connection (.rdp) file in Notepad.
                Step 2. Change the line compression:i:1 to compression:i:0.
                Step 3. Save the file.
2. Disabling Encryption
Registry keys:
• Set HKLM\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp\MinEncryptionLevel to 1.
• Create HKLM\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp\SecurityLayer as a DWORD value and set it to 0.
• Restart PC.
Is this the same procedure followed?
We tried disabling the compression with no luck. Will try doing the step 2 as well.
Dinesh
johng231 Tue, 06/08/2010 - 17:54
Do you recommend setting the RDP policy to Full TFO after you have disabled compression/encryption on the client side?
Eric Rose Wed, 06/09/2010 - 05:58
  • Cisco Employee,
Yes, if you modify the default setting for RDP. In order to gian the benefits or disabling compression/encryption, you have to modify the default policy to full optimization.
Thanks.
dinesh.thathana... Wed, 06/09/2010 - 09:50
Finally got the RDP optimization working.
The terminal server was overriding the compression settings done on Default.RDP file. Once the seetings on Server was done for disabling encryption and compression, everything just worked great. Many thanks to you guys.
Any idea even after 80% optimization, why on the following output Bytes written for optimized traffic is more than Bytes written for original traffic?
Connection Id:            14800
    Peer Id:                  00:21:5e:73:0e:cf
    Connection Type:          EXTERNAL SERVER
    Start Time:               Wed Jun  9 11:21:36 2010
    Source IP Address:        192.168.120.199
    Source Port Number:       3600
    Destination IP Address:   192.168.1.174
    Destination Port Number:  3389
    Application Name:         Remote-Desktop
    Classifier Name:          MS-Terminal-Services
    Map Name:                 basic
    Directed Mode:            FALSE
    Preposition Flow:         FALSE
    Policy Details:
           Configured:        TCP_OPTIMIZE + DRE + LZ
              Derived:        TCP_OPTIMIZE + DRE + LZ
                 Peer:        TCP_OPTIMIZE + DRE + LZ
           Negotiated:        TCP_OPTIMIZE + DRE + LZ
              Applied:        TCP_OPTIMIZE + DRE + LZ
    Accelerator Details:      None
                                    Original            Optimized
    Bytes Read:                      5818686                58462
    Bytes Written:                     50869              1075183
    Total Reduction Ratio: 80.686%
Any thoughts?
Dinesh
Eric Rose Wed, 06/09/2010 - 12:20
  • Cisco Employee,
                                   Original            Optimized
These number are based in each direction from my understansing.
from the reference guide.
Number of bytes that have been read and written on  the original (incoming) side and the optimized (outgoing) side.
you should look at the DRE statistics for this connection to get the reduction values in both directions.
dinesh.thathana... Wed, 06/09/2010 - 20:40
Yes thats right Eric.
But optimized traffic cannot be more than original isn't it?. The Ref guide doesnt really talk about this in detail.
-Dinesh
