Category 6 cabling and SFP module
Jun 1st, 2010
I have a 2960 Switch which has 2 ports dual T/SFP module. I want to use these two duals uplink ports for a category 6 coper cable.
My problem is that on cisco, I have the GLC-T SFP module for that port to support cabling connection but it says only for category 5 cable.
Can I also use that SFP module for category 6 cable ? if not, does Cisco has another SFP module which is compliant with category 6 cable ?  can somebody gives a hint ?
Thanks.
Reza Sharifi Tue, 06/01/2010 - 12:10
  • Cisco Designated VIP,
    2017 LAN
Paul,
According to this paper GLC-T SFP is supported on the these switches only. I don't see 2960 in the list
Speeds Supported by the 1000BASE-T(GLC-T) SFP Module on the Cisco Catalyst 3750 Series Switch
The 1000BASE-T SFP can support 10/100/1000 speeds only on the Cisco Catalyst 2970, 3560, and 3750 Series Switches.
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml#support6
Reza
Leo Laohoo Tue, 06/01/2010 - 14:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
That's because the 2960 (8 and 24-port only) has dual personality ports.  You can use EITHER the copper port or the SFP therefore the GLC-T doesn't make any sense installing it into this particular model.  Trying to understand, though, the reasoning behind why it's not supported on the 48-port variety.
coletemple Wed, 06/02/2010 - 03:32
Thanks for your answers guys. To sum up: can I use a coper cable category 6
on these uplink ports without any adapter ? if not, what adapter to use on these gig ports for category 6 coper cable ?
thanks
Leo Laohoo Wed, 06/02/2010 - 04:39
  • Hall of Fame,
    2017 LAN, Wireless
On a 2960 switch?  Yes, you can use Cat5/5e/6 in the Gig SFP/copper ports.
coletemple Wed, 06/02/2010 - 08:54
thanks Leolaohoo.
if i am using a cat 6 coper on the 2960 port, do I need an adapater or I just need to plug the cable on the port ? sorry to ask these questions as I can't see a real 2960 in front of me to work that out
Leo Laohoo Wed, 06/02/2010 - 16:44
  • Hall of Fame,
    2017 LAN, Wireless
To plug a copper to a 2960/2960G/2960S uplink port, just plug it straight in.
Leo Laohoo Thu, 06/03/2010 - 16:38
  • Hall of Fame,
    2017 LAN, Wireless
If this has resolved your issue, can you mark this post as "Answered"?  Thanks.
