VPN client works on one system and not another
Jun 1st, 2010
I have VPN Client 4.0.5 (D) on two systems.  One works correctly, the other acts like it is connecting and then prompts for the user name and password again like it was typed incorrectly.  the same pcf profile file is being used.  Any ideas where to start looking?
Jennifer Halim Wed, 06/02/2010 - 04:10
  • Cisco Employee,
What OS are you running it on? What headend device are you terminating the VPN on, and what version?
Also enable the vpn client logging, and grab the logs after you tried to connect.
You might want to uninstall the VPN client version as 4.0.5 is pretty old and install the latest version.
