preference not working
Jun 1st, 2010
Hi have this config working with preference:
dial-peer voice 100 pots
translation-profile incoming SIP
preference 1
service session
destination-pattern T
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits all
dial-peer voice 200 pots
preference 3
service session
no digit-strip
direct-inward-dial
port 2/0:15
forward-digits all
dial-peer voice 201 pots
preference 4
service session
no digit-strip
direct-inward-dial
port 2/1:15
forward-digits all
So when I place a call, the debug shows:
May 17 16:08:12.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=0996456750
   Result=Success(0) after DP_MATCH_DEST
May 17 16:08:12.931: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=100
     2: Dial-peer Tag=200
     3: Dial-peer Tag=201
May 17 16:08:12.931: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 0996456750
Which is right because it use the preference order.
But if I add,
dial-peer voice 9100 pots
preference 10
service session
destination-pattern 09........
no digit-strip
direct-inward-dial
port 2/1:15
forward-digits all
dial-peer voice 8098 pots
preference 8
service session
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits all
The same call, doesnt use the preference order, it prefers a dial-peer with higher preference
May 17 16:13:41.187: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9100
     2: Dial-peer Tag=8098
     3: Dial-peer Tag=200
     4: Dial-peer Tag=100
     5: Dial-peer Tag=201
May 17 16:13:41.187: ISDN Se2/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 0996456750
And if dial-peer 8098 is erased and recreated with another tag, like this:
dial-peer voice 9298 pots
preference 8
service session
no digit-strip
direct-inward-dial
port 1/0:15
forward-digits all
with the same call, it seems is using the tag instead of preference...
May 17 16:16:28.703: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9298
     2: Dial-peer Tag=9100
May 17 16:16:28.707: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 0996456750
Should I replace the IOS? it´s c3845-spservicesk9-mz.123-14.T7.bin
Any suggestion will be helpful
TIA
Andres Pasten
Adexus S.A.
Richard Bradfield Tue, 06/01/2010 - 15:52
  • Silver, 250 points or more
Do you get the same order if you do a "show dialplan number 0996456750"
this will list the dial peers in order of best match which includes the preference
also the IOS is a bit old I would at least go to 124-15T8 or later
andres.pasten Fri, 06/18/2010 - 07:43
Sorry about the delay, but I have made the requested test, and using show dialplan number shows different order than the real call:
1.- Sh dial-peer voice sum
sh dial-p voice sum
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
10     voip  up   up             84..               0  syst ipv4:172.17.96.58
100    pots  up   up             T                  1                      up   1/0:15
101    pots  up   up             T                  0                      down 1/1:15
11     voip  up   up             95..               0  syst ipv4:172.17.96.58
20     voip  up   up             35..               0  syst ipv4:172.17.96.58
21     voip  up   up             36..               0  syst ipv4:172.17.96.58
200    pots  up   up             T                  3                      up   2/0:15
201    pots  up   up             T                  4                      up   2/1:15
99     voip  up   up             7777               0  syst ipv4:172.17.96.58
4000   voip  up   up             237048004...       0  syst ipv4:22.170.96.1
9098   pots  up   up             09........         8                      up   1/0:15
9100   pots  up   up             09........        10                      up   2/1:15
2.- show dialplan number
sh dialplan number 0996456750
Macro Exp.: 0996456750
VoiceEncapPeer9098
        peer type = voice, information type = voice,
        description = `',
        tag = 9098, destination-pattern = `09........',
        answer-address = `', preference=8,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 9098, Admin state is up, Operation state is up,
        Outbound state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = disabled,
        in bound application associated: 'session'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):SIP
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        type = pots, prefix = `',
        forward-digits all
        session-target = `', voice-port = `1/0:15',
        direct-inward-dial = enabled,
        digit_strip = disabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 0, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "",
        Last Disconnect Text is "",
        Last Setup Time = 0.
Matched: 0996456750   Digits: 2
Target:
VoiceEncapPeer9100
        description = `',
        tag = 9100, destination-pattern = `09........',
        answer-address = `', preference=10,
        group = 9100, Admin state is up, Operation state is up,
        URI classes:
            Destination =
        dnis-map =
        permission :both
        forward-digits all
        session-target = `', voice-port = `2/1:15',
Target:
3.- debug isdn q931and csim start 0996456750
csim: called number = 0996456750, loop count = 1 ping count = 0
Jun 17 15:21:30.311: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=0996456750, Peer Info Type=DIALPEER_INFO_SPEECH
Jun 17 15:21:30.311: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     2: Dial-peer Tag=9098
Jun 17 15:21:30.323: ISDN Se2/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 0996456750
Jun 17 15:21:30.323: ISDN Se2/1:15 Q931: TX -> SETUP pd = 8  callref = 0x2857
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Called Party Number i = 0x80, '0996456750'
                Plan:Unknown, Type:Unknown
Jun 17 15:21:30.375: ISDN Se2/1:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xA857
Jun 17 15:21:30.375: ISDN Se2/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xA857
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Jun 17 15:21:35.775: ISDN Se2/1:15 Q931: RX <- ALERTING pd = 8  callref = 0xA857
So, do you reccomend upgrade the IOS to 12.4-15T or later. Some specific version of any one?
TIA
Andres Pasten Calzada
Adexus S.A.
andres.pasten Wed, 07/21/2010 - 12:12
Finally I´ve made an upgrade to c3845-spservicesk9-mz.124-15.T13, and the issue persists. I´ve checked the config and found nothing strange. Any idea of something I need to check out?
TIA
Andres Pasten C.
Adexus S.A.
