06-01-2010 01:36 PM
Hi All,
I have amber led ON for System-error (on operator information panel) in the WAE 674 box. When I log in the box , i am not finding any alarms ( Not even Minor) in the box. When i go through the syslogs , i dont see any output for any errors. I have no idea when lights started to be ON but want to know what would be the cause .
Solved! Go to Solution.
06-01-2010 01:55 PM
This light indicates some type of hardware fault with the default. To isolate which hardware component has failed, you'll need to remove the cover from the device. With the cover removed and the device powered on, there will be an amber or red light next to the component (memory, etc.) that has failed.
Zach
06-01-2010 01:55 PM
Zach
