UCCX 7 and SQL View
Jun 1st, 2010
Does UCCX7 support SQL Views instead or a table? I see under the DB READ step that I can see all the available Views for the user but I'm getting a SQL connection error when I run reactive debugging. My SQL statement returns 1 row so I know the statement is accurate.
Anthony Holloway Wed, 06/02/2010 - 13:56
Yes, it does support Views.  In fact, using a view is a valid way around the current limitation of not being able to read records from different tables in one SQL statement.
i.e., This wont work in the editor:
SELECT a.name, b.age FROM people AS a, birthdays AS b WHERE a.name = 'Anthony'
Message was edited by: Anthony Holloway - Wow this forum software really upsets me.
michael.huelskoetter Wed, 01/27/2016 - 08:01
Hi Anthony,
can you please tell me, how to edit the jdbc driver URL in case I use a db view?
My customer gave me access to a view and I can't setup a successful db connection.
Many thanks in advance!
Best regards,
p.s.: In the meantime we're using Rel. 10.6 :- ))
Anthony Holloway Wed, 01/27/2016 - 08:16
I'm sorry, but I don't know the answer.  I would ask that you post this question in your own topic thread for wider visibility and help.
Deepak Rawat Wed, 01/27/2016 - 08:39
Are you following the instructions mentioned in the below Admin Guide to setup DSN connection:
BTW which DB server are you using, make sure it is one of the supported one as mentioned in the below Compatibility Matrix:
Gergely Szabo Wed, 01/27/2016 - 08:45
what is the error message you are getting?
Are you able to create the JDBC connection or does it fail, too?
