configure local passwords
Jun 1st, 2010
I have trying to configure local/console passwords on a 3750 running ssh2, and ssh2 is working.
The local username and password and configured. The line vty 0 15 is configured,
When I disable AAA I am unable to login using the local username and password. What steps am I missing to get the local username and password to work while running ssh2
Overall Rating: 2 (1 ratings)
DuaneKPetersen Wed, 06/02/2010 - 07:17
Unable to view the link, get message listed below.
Forbidden File or Application
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
If you feel you have reached this page in error, please try one of the following methods to locate your document:
  1. If you are manually entering the URL into your browser location bar, be sure to include the file name of the page you are trying to access (file names typically end in .htm, .html or .shtml).
  2. Use the Search feature located in the upper right section of this page.
  3. Return to the Cisco.com Home or select a primary site area from the top navigation bar.
  4. Consult with your Cisco Account Manager to confirm you have the appropriate entitlement to access this page.
If you would like to contact someone about this problem, please click on the Contacts & Feedback link below.
DuaneKPetersen Tue, 06/08/2010 - 14:57
Unable to get the link listed in your reply, could you please check the link or attach the file in your next reply,
