Router config-register 0xC502
Jun 1st, 2010
Hi All,
I have Cisco 2811 Router and few days ago my router doesn't work correctly. I checked config and found config-register waas changed (0xC502).
HUV_Murun#sh version
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 16:35 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
HUV_Murun uptime is 23 hours, 36 minutes
System image file is "flash:c2800nm-ipbase-mz.124-9.T7.bin"
Cisco 2811 (revision 53.50) with 251904K/10240K bytes of memory.
Processor board ID FHK1228F2RY
2 FastEthernet interfaces
1 Serial interface
6 Channelized E1/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0xC502
Anybody know what is the meaning of this config-register (0xC502) and how can be changed config ?
BR,
Tuvshuu
Leo Laohoo Tue, 06/01/2010 - 18:59
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Go to configuration mode and enter the command "config-register 0x2102".
Use of the Configuration Register on All Cisco Routers
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
Please don't forget to rate useful posts.  Thanks.
michael.leblanc Wed, 07/14/2010 - 09:18
  • Silver, 250 points or more
Tuvshuu:
Although I have not used it in a very long time, there is a free software utility "Config Reg Calculator" offered by Boson, which "allows you to determine what a router will do given the configuration  register value".
It is available at:
http://www.boson.com/FreeUtilities.html
Perhaps it might be of interest to you.
Best Regards,
Mike
haneez2949 Mon, 10/22/2012 - 23:16
Tuvshuu::
config-register (0xC502)  means
C- 15th and 14th bit set
14th-IP broadcasts do not have network numbers
15th-Enable diagnostic messages and ignore NVRAM contents
5- 8th & 10th bit set
8th-Break disabled
10th-IP broadcast with all zeros
0-
2-Boot field
Thanks and regards.
HNZ
