CME and CUE 8.0
Jun 1st, 2010
So i have installed:
CME (c2951-universalk9-mz.SPA.151-1.T.bin, 8.0.0)
CUE (CUE 8.0.1)
I notice when I log into to the ip address of the ISM-SRE, to launch the Unity Express page, I noticed I am not able to configure extension.
I have to go to the CME address x.x.x.x/ccme.html to configure extension.
Did I miss some thing here. Does Unity Express 8.0.1 not allow you to configure extension?
Kallol
Overall Rating: 3.8 (5 ratings)
Walter Solano Wed, 06/02/2010 - 06:45
  • Gold, 750 points or more
Hello Kallol,
That its completely true, our developers decided to remove all of the CME menus from the the CUE gui, unfortunately I don't know the specific reason of the change but its the way that was design for CME/CUE v.8. if you would like to use CME features like configure phones and extension you should use the CME GUI.
Please rate this post if was helpful
Walter Solano
Cisco UCCX Specialist
I am having similar issue 15.1.1.T on 2921 router. However the CME admin pages will not load for me in web page http://x.x.x.x/ccme.html
Throws an error on the web page "view page" with no content.
Been working with TAC and waiting almost a week now, and waiting for a response from the development team. Customer is hosed....thanks Cisco
The CCME GUI files I have installed in the router flash are from the cme-full-8.0.0.0.tar package on CCO.
What package did you use for your CME gui files?
CUE 8.0.1 gui works fine.
thanks
voiceisip Tue, 06/08/2010 - 12:31
I ran into the same issue, when i was loadinf CME files.
Have you tried...cme-basic-8.0.0.0.tar
Here is a list of the file in Flash. Maybe the size file difference we let us know if there is a different file i have than u.
CharlotteCME#sh flash
-#- --length-- -----date/time------ path
1          780 Jun 02 2010 13:28:50 vlan.dat
2       677820 Jun 01 2010 21:38:36 admin_user.js
3         2903 Apr 16 2010 22:13:04 cpconfig-29xx.cfg
4      2915328 Apr 16 2010 22:13:16 cpexpress.tar
5         1038 Apr 16 2010 22:13:28 home.shtml
6       115712 Apr 16 2010 22:13:44 home.tar
7      1697952 Apr 16 2010 22:14:02 securedesktop-ios-3.1.1.45-k9.pkg
8       415956 Apr 16 2010 22:14:14 sslclient-win-1.1.4.176.pkg
9     56975740 Jun 01 2010 19:42:04 c2951-universalk9-mz.SPA.151-1.T.bin
10     2591877 Jun 01 2010 20:32:38 APPS-1.3.3.SBN
11     4573696 Jun 01 2010 20:32:44 apps11.8-5-3TH1-6.sbn
12     2933329 Jun 01 2010 20:32:50 apps41.8-5-3TH1-6.sbn
13     2935993 Jun 01 2010 20:32:54 apps42.8-5-3TH1-6.sbn
14       44896 Jun 01 2010 20:32:54 BOOT69xx.0-0-0-14.zz
15        7205 Jun 01 2010 20:32:56 CME-8-0-Basic-Readme-v.1.0.txt
16      503269 Jun 01 2010 20:32:56 cnu11.8-5-3TH1-6.sbn
17      499644 Jun 01 2010 20:32:58 cnu41.8-5-3TH1-6.sbn
18      524917 Jun 01 2010 20:32:58 cnu42.8-5-3TH1-6.sbn
19         900 Jun 01 2010 20:33:00 CP7921G-1.3.3.LOADS
20     2104751 Jun 01 2010 20:33:02 cvm11sccp.8-5-3TH1-6.sbn
21     2101414 Jun 01 2010 20:33:06 cvm41sccp.8-5-3TH1-6.sbn
22     2099070 Jun 01 2010 20:33:10 cvm42sccp.8-5-3TH1-6.sbn
23      340615 Jun 01 2010 20:33:10 dsp11.8-5-3TH1-6.sbn
24      537925 Jun 01 2010 20:33:12 dsp41.8-5-3TH1-6.sbn
25      340615 Jun 01 2010 20:33:12 dsp42.8-5-3TH1-6.sbn
26      264368 Jun 01 2010 20:33:14 DSP69xx.0-0-0-3.zz
27           0 Jun 01 2010 20:33:14 gui
28     1848343 Jun 01 2010 20:33:26 GUI-1.3.3.SBN
29     1616686 Jun 01 2010 20:33:30 jar11sccp.8-5-3TH1-6.sbn
30     1628021 Jun 01 2010 20:33:32 jar41sccp.8-5-3TH1-6.sbn
31     1756328 Jun 01 2010 20:33:36 jar42sccp.8-5-3TH1-6.sbn
32        1916 Jun 01 2010 20:33:36 MISC-1.3.3.SBN
33      496521 Jun 01 2010 20:33:36 music-on-hold.au
34         670 Jun 01 2010 20:33:38 SCCP11.8-5-3S.loads
35         650 Jun 01 2010 20:33:38 SCCP41.8-5-3S.loads
36         670 Jun 01 2010 20:33:38 SCCP42.8-5-3S.loads
37          61 Jun 01 2010 20:33:38 SCCP69xx.8-5-3-0.loads
38     1906272 Jun 01 2010 20:33:42 SCCP69xx.8-5-3-0.zz
39     2083047 Jun 01 2010 20:33:46 SYS-1.3.3.SBN
40         674 Jun 01 2010 20:33:46 term06.default.loads
41         674 Jun 01 2010 20:33:46 term11.default.loads
42         654 Jun 01 2010 20:33:46 term41.default.loads
43         674 Jun 01 2010 20:33:48 term42.default.loads
44         654 Jun 01 2010 20:33:48 term61.default.loads
45         674 Jun 01 2010 20:33:48 term62.default.loads
46      896477 Jun 01 2010 20:33:50 TNUX-1.3.3.SBN
47     1379535 Jun 01 2010 20:33:52 WLAN-1.3.3.SBN
48      146463 Jun 02 2010 14:08:48 B015-1-0-3.SBN
49        3987 Jun 01 2010 21:38:34 admin_user.html
50        1029 Jun 01 2010 21:38:36 CiscoLogo.gif
51         617 Jun 01 2010 21:38:36 CME_GUI_README.TXT
52         953 Jun 01 2010 21:38:38 Delete.gif
53       16344 Jun 01 2010 21:38:38 dom.js
54         864 Jun 01 2010 21:38:38 downarrow.gif
55        6146 Jun 01 2010 21:38:38 ephone_admin.html
56        4558 Jun 01 2010 21:38:38 logohome.gif
57        3866 Jun 01 2010 21:38:40 normal_user.html
58       78428 Jun 01 2010 21:38:40 normal_user.js
59        1347 Jun 01 2010 21:38:40 Plus.gif
60         843 Jun 01 2010 21:38:40 sxiconad.gif
61         174 Jun 01 2010 21:38:40 Tab.gif
62        2432 Jun 01 2010 21:38:42 telephony_service.html
63         870 Jun 01 2010 21:38:42 uparrow.gif
64        9968 Jun 01 2010 21:38:42 xml-test.html
65        3412 Jun 01 2010 21:38:42 xml.template
66     8115790 Jun 02 2010 14:09:04 apps37sccp.1-4-1-0.bin
67      291951 Jun 02 2010 22:35:00 dsp11.8-2-0-55.sbn
68      394262 Jun 02 2010 22:35:20 jar11sccp.8-2-0-55.sbn
69         658 Jun 02 2010 22:36:04 SCCP11.8-2-1S.loads
70     2358702 Jun 02 2010 22:36:24 apps11.8-2-0-55.sbn
71      438136 Jun 02 2010 22:36:42 cnu11.8-2-0-55.sbn
72     2144551 Jun 02 2010 22:36:56 cvm11sccp.8-2-0-55.sbn
147152896 bytes available (113020928 bytes used)
thanks for the info....it runs out the file set that I worked is named:
cme-gui-8.0.0.0.tar
Release Date: 30/)ct/2009
CME 8.0 Updated GUI files for IOS 15.0(1)XA releases
Size: 810.00 KB (829440 bytes)
even though these files are labed as for IOS 15.0(1)XA releases they are the only ones that would work with 15.1.1T
ahalstea Fri, 01/07/2011 - 19:47
I have had the same issue.  Promised the customer a GUI ..... and said "yes they have it all in the same  webpage if you are using the CUE software" now I have some sales dancing to do ...
WHY??????/
Andy
