NAM Upgrade from 3.6(1b) to 4.0 or 4.2
Jun 1st, 2010
Dear All
I followed the instruction from the Document "Cisco Branch Router Series (NME-NAM) Installation and Configuration Note, 4.2" and the URL is "
http://www.cisco.com/en/US/docs/net_mgmt/network_analysis_module_software/4.2/branch_router/configuration/guide/BRincfg_42.html"
to upgrade the NAM application software. I got the error message (in RED):
     Download NAM application image via tftp and write to HDD
     server IP address [10.20.254.35]:
     full pathname of application image []: nam-app-x86_32.4-2-1.bin.gz
     Getting nam-app-x86_32.4-2-1.bin.gz from 10.20.254.35 via tftp.
     tftp> tftp> tftp>
     zcat: stdout: No space left on device
     upgrade.bin size: 73474048
     File transfer successful.
     Checking upgrade.bin
     bad magic number.
     bad magic number.
     File upgrade.bin is not a valid NM-NAM application image!
The error message seems to me I do NOT have enough space to download the NAM application image, but I could be wrong. However I shall have enough space on the HDD to save the image file.
My equpiment details are below:
Cisco 3845 (revision 1.0) with 477183K/47104K bytes of memory.
Processor board ID FHK1318F04P
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco Integrated Service Engine(s)
   Network Analysis Module (NME-NAM) 3.6(1b)
in slot 4
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
126976K bytes of ATA System CompactFlash (Read/Write)
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
NAME: "Integrated Service Engine for Modular and Integrated Services Routers on Slot 4", DESCR: "Integrated Service Engine for Modul
ar and Integrated Services Routers"
PID: NME-NAM-120S      , VID: V01 , SN: FOC125172K8
Please help.......Thank in advance..
Kelvin Cheung
Calin Chiorean Wed, 06/02/2010 - 03:20
Indeed it's saying that you don't have enough space left, and the image downloaded is then incomplete. Have you checked how much space left you have? As I see the image, you need at least 80MB.
Maybe you can delete some old files.
If this advice helps, please rate it!
Thank you!
cheung2009 Wed, 06/02/2010 - 19:02
Dear Calin
I have about 63GB free disk space. I assumed the application image would be downloaded to the hard disk, But it seemed not the case.
Kelvin Cheung
mikewhitton Sat, 06/12/2010 - 18:56
I was running into the same issue, I believe this has something to do with the way tftp works on this device.  When I copied the application binary to an FTP server and downloaded onto the device the process completed successfully:
Download NAM application image via ftp and reformat & write to HDD
URL of application image [ftp:[email protected]/home/mikew/nm-nam/nam-app.4-0-1.bin.gz]: ftp:[email protected]/home/mikew/nm-nam/nam-app-x86_32.4-0-1a.bin.gz
Getting ftp:[email protected]/home/mikew/nm-nam/nam-app-x86_32.4-0-1a.bin.gz.
Password for [email protected]:
ftp:[email protected]/home/mikew/nm-nam/nam-app-x86_32.4-0-1a.bin.gz (84797K)
-                         [########################]   84797K | 1533.20K/s
86832713 bytes transferred in 55.31 sec (1533.20k/sec)
upgrade.bin size: 88250390
Do you want to proceed installing it? [y/N] y
Initializing the hard disk. This process may take several minutes...
Applying the image, this process may take several minutes...
Performing post install, please wait...
Application image upgrade complete. You can boot the image now.
Cisco Systems, Inc.
Services engine helper utility for NM-NAM
Version 1.1(1b) [200806251439]
NAM appliation version: 4.0(1a)
Flash helper image: nm-nam-helper.1-1-1b
