BGP declaration
Answered Question
Jun 2nd, 2010
Good day, Everyone.
Could someone advise me the reason of declaring BGP without being used.
router bgp 12345
     no synchronization
     bgp router-id A.B.C.D
     bgp log-neighbor-changes
     no auto-summary
There is no declaration about connected networks and neighbors in it as above. Does it make any sense to have BGP config like this? Thanks much in advance for your contribution.
Lay
Correct Answer by Giuseppe Larosa about 6 years 7 months ago
Hello Lay,
BGP sessions can be built with configured neighbors only.
However, with BGP process running the system will be listening on TCP port 179.
So yes it is better to remove it because it is unused
Hope to help
Giuseppe
Overall Rating: 4.5 (2 ratings)
Giuseppe Larosa Wed, 06/02/2010 - 02:38
Hello Lay,
if there are no network commands, no neighbor commands, no redistribute commands the BGP process will be idle.
I think that someone has added the BGP configuration just as a placeholder for future deployment or he/she has forgotten to remove the process after cleaning up BGP configuration
you just need to use
no router bgp 12345
to remove it if you want/need to do it
Hope to help
Giuseppe
layhlaing Wed, 06/02/2010 - 05:54
Hi Giuseppe,
Thanks much for your sharing. If the BGP is at its idle stage, I would prefer to take it out. It can be left as a comment for future reference. Cisco recommends to disable unused protocols/services as a security best practice. Do you think BGP is the same?
Lay
Correct Answer
Giuseppe Larosa Wed, 06/02/2010 - 07:15
Hello Lay,
Hope to help
Giuseppe
