Access lists not working ?
Jun 2nd, 2010
recently i helped one of my customer to migrate some LAN pts from nortel baystack to cisco 3750 switch.
previously, a nortel baystack was connected to the cisco 3750 through a trunk port, this nortel has only 1 LAN pt on one VLAN only.
the LAN pt was migrated to the cisco 3750, and I assigned the VLAN on the cisco 3750 for this particular port.
the cust found that it is not able to ping after the migration.
on this particular VLAN, there is one access-list implemented.
client -> nortel -> cisc0 3750 Gi1/0/6 -> router
old config
interface GigabitEthernet1/0/6
switchport mode trunk
interface Vlan6
description Swimming Pool Vlan
ip address 172.25.101.1 255.255.255.0
ip access-group spool in
ip access-list extended spool
permit ip host 172.25.101.110 host 172.22.102.102
deny   ip any any
client -> cisc0 3750 Gi1/0/6 -> router
new config
switchport access vlan 6
switchport mode access
spanning-tree portfast
interface Vlan6
  deny   ip any any
IP 172.25.101.110 is the client connected to GigabitEthernet1/0/6, while 172.22.102.102 is at HQ office.
now 172.25.101.110 cannot reach 172.22.102.102.
the only difference is that vlan 6 is not on the cisco 3750 instead of the nortel baystack.
is there anything wrong with the config ??
Giuseppe Larosa Wed, 06/02/2010 - 02:44
Hello Yeow,
you have changed the default gateway for the client
verify that:
the client is using 172.25.101.1 as its default gateway with ipconfig /all in the shell (if it is a windows os)
use arp -g to verify that MAC address associated to default gateway is the same as that of SVI Vlan6 on the C3750
SVI MAC address is reported in sh int vlan6 output
Hope to help
Giuseppe
Ganesh Hariharan Wed, 06/02/2010 - 09:41
old config
interface Vlan6
deny   ip any any
new config
It should work just check few things are you able to ping the default gateway that 3750 vlan interface ip address from client and from switch are you able to ping the destination server ip address 172.22.102.102 and finally as you have removed on device just clear arp from client pc and the try.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
