VG224 integration with CUCM 8
Jun 2nd, 2010
Hi All,
I am new to Cisco IPT.
I would like to integrate Vg224 with CUCM8. The VG224 will be used to connect FAX & Analog Phones.
Could you please let me know which protocol (H323/MGCP/SSCp) should I use to integrate with CUCM.
Nirmal
Nirmal Paria Wed, 06/02/2010 - 03:18
Thanks for your quick suggestion. I have a small query on it.
Will FAX work fine with SCCP configuration mode ?
Nirmal
