SIP Trunk between CME and CUCM 7.x
Jun 2nd, 2010
Dear All
Is there any document available from Cisco to configure SIP trunk between CME and CUCM 7.x
Also want to know corporate direcory can be merged between CME and CUCM?
Jaime Valencia Wed, 06/02/2010 - 07:22
As with H323, all you need is a SIP dial peer pointing to the CUCM with the destination pattern of what you want to dial and on CUCM configure a SIP trunk pointing to the CME router.
You'd need to create a custom directory to merge the directories from the system as there is no native way
If this helps, please rate
