WLSE to WCS Issues
Jun 2nd, 2010
Hi All
I have an old WLSE from a customer that has been converted to WCS Ver 4.0.96.0 and there are some issues:
1. The root password for the Linux operating system has been lost.
Anyone know a recovery mechanism?
2. The serial port doesn't seem to work with standard 232 cross-over cable, 9K6 and 8N1 no flow control etc.
Anyone know the pinout of the serial port?
3. Although the box has been converted to WCS, the Linux OS appears to be version 2.6 - I want to upgrade the WCS to version 6.0.181.0 and for that I need to be on version 5 of Linux. I thought the conversion process from WLSE to WCS included an upgrade of Linux to version 3.
Anyone have any experience or comments?
Any help gratefully received.
Roger
sschmidt Wed, 06/02/2010 - 06:47
  • Cisco Employee,
Can you try this procedure ( from location appliance but should be same ):
Recovering a Lost Root Password
If you lose or forget the root password for the location appliance,  follow these steps:
Step 1 When the GRUB screen comes up, press Esc to enter the boot menu.
Caution If you forget the GRUB password, you cannot login  and you will need to contact TAC to arrange for an RMA.
Step 2 Press e to edit.
Step 3 Navigate to the line beginning with "kernel," and  press e.
At the end of the line enter a space and the number one (1). Press Enter to save this  change.
Step 4 Press b to begin boot  sequence.
At the end of the boot sequence, a shell prompt appears.
Note The shell prompt does not appear  if you have set up a single user mode password.
Step 5 You can change the root password by entering the passwd command.
Step 6 Enter and confirm the new password.
Step 7 Restart the machine.
The one on the back should be standard.  Is it not working?
That is the kernel version ( 2.6 ).
Open a ticket with TAC.  With a valid support contract we can post an .iso for the upgrade to RH 5 to support WCS 6.x.
Trending Topics - Security & Network
