Nexus7000 Boot issue " Status 90: Loading Boot Loader "
Jun 2nd, 2010
Hi Gents,
I have currently upgraded a NX7k to NX-OS 5.0.2 .
Now I am stuck by rebooting the system (check output below)
No chang after a manual power off and on the System.
Does anybody know how to get out of this boot process ?
Thanks in advanced for your feedback
Saluti
Alibani
<< console output >>
This command will reboot the system. (y/n)?  [n] y
2010 Jun  2 09:10:20 FOR110R050_Labor %$ VDC-1 %$ %PLATFORM-2-PFM_SYSTEM_RESET: Manual system restart from Command Line Interface
writing reset reason 9,
3 votes
Yediael Christian Sun, 11/24/2013 - 20:14
Hi oizcioliz,
I also haev the same problem like you. Has it already been solved? What kind of actions that did to resolve this problem?
thanks.
best regards,
Yedi
wilhelm.putz Sun, 11/24/2013 - 22:49
Hi Yedi,
I fixed the problem by clearing the nvram of the sup. I removed the onboard battery, waited some time (approx 1 minute) il and then put it back. After that procedure my sup came up.
regards
Willi
