Ethernet CFM on 7600 ES+ ports
Jun 2nd, 2010
I'd like to be able to configure an inward (UP) facing MEP on the ES+ interface as I have directly attached (unmanaged) CPE.
Is this possible in 12.2(33)SRE1?
When i try and apply a MEP to the physical interface or service instance I see the following message.
router(config-if)# ethernet cfm mep domain CUSTOMER mpid 1 vlan 7
Up direction MEP is not supported on Gi7/19. Command Aborted.
Ganesh Hariharan Mon, 06/14/2010 - 04:18
Check out the usage guideline for MEP in cisco 7600 routers,
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Related Content
