FXOs with celular stations
Jun 2nd, 2010
I have a issue which I´m not able to identify yet.
- PSTN: E1-CAS-R2, works fine.
- PSTN: 2 x FXO for celular stations. Outbound call works fine. Inbounds calls doesnt work well at all.
Looks like a problem with the DTMF. After the AA shows the options, the AA do not accept any input keystroke.
the show run:
trunk group ALL_FXO
hunt-scheme longest-idle both
voice-port 0/0/0
trunk-group ALL_FXO 1
cptone CO
connection plar 8100
voice-port 0/0/1
cptone CO
dial-peer voice 1 pots
translation-profile incoming PSTN-IN
incoming called-number .
direct-inward-dial
dial-peer voice 8100 voip
description ** CUE AA number **
destination-pattern 8100
b2bua
session protocol sipv2
session target ipv4:172.26.1.8
dtmf-relay sip-notify
codec g711ulaw
no vad
Show ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
I need some ideas.
Thanks.
RJB
