Can I assign more than 1 vlan to a sub-interface when running an ASA transparently using contexts?
Jun 2nd, 2010
I have a client who want to run an ASA5550 transparently using contexts in multiple mode as below.
Context 1: Service
Incoming trunk containing 81 and 82
Output trunk containing 86 and 87
81 -> 86
82 -> 87
Context 2: Management
Incoming trunk containing 10,11,12,13,14,15
Output trunk containing 70,71,72,73,74.75
10 -> 70
11 -> 71
12 -> 72
13 -> 73
14 -> 74
15 -> 75
I was under the impression from what I have read that you could only have 2 vlans per context, 1 on each interface/sub-interface and therefore for this to work they would have to split it down into 14 contexts. Am I correct or can you add more vlans to each context interface? unfortunatly I do not have a lab I can use to test this scenario.
Any input greatly appreciated!
m.kafka Wed, 06/02/2010 - 16:10
  • Bronze, 100 points or more
you can configure many VLANs in the system context and asign them to transparent firewall contexts via the "context" command, If the firewall contexts are transparent you can only assign a maximum of two for each transparent FW. Solution: upgrade the number of contexts via licensing.
In your case 8 simultaneous contexts:
81 -> 86 - ctx 1
82 -> 87 - ctx 2
10 -> 70 - ctx 3
11 -> 71 - ctx 4
12 -> 72  -ctx 5
13 -> 73 - ctx 6
14 -> 74 - ctx 7
15 -> 75  -ctx 8
Rgds, MiKa
