supported hardware
Answered Question
Jun 2nd, 2010
I am getting ready to implement a VMWare server virtualization solution.  I have had about 6 different vendors propose solutions, however up until this last one (NETAPP) I had not even considered what hardware Cisco would support their software on (CCM, Unity, CUBAC, etc)  Is there a list of supported hardware/software solutions?  I am looking to virtualize thing like CCM, CUBAC, ACS etc
Correct Answer by Jaime Valencia about 6 years 10 months ago
Review requirements here
Deploying Unified Communications on Virtualized Servers
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/models.html#wp1128373
EDIT: Just to add to Bill's advise I know CUXAC are planned for VMware, last thing I heard was summer 2010 but there were no ETAs or versions confirmed
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Correct Answer by William Bell about 6 years 10 months ago
Chad,
I am trying to get my head around this one too.  I have started doing a write up on the "UC on UCS" model and UC virtualization.  You may find some of this information useful (hopefully):
http://www.netcraftsmen.net/resources/blogs/uc-on-ucs-virtualizing-the-unified-communications-core.html
At the bottom of the blog, you will find two very useful links.  One will give you the bare metal hardware requirements and the second will send you to the Cisco DocWiki on UC virtualization.  Note that the offering for certain UC apps is somewhat limited at this time.  Cisco plans on expanding the options for users very quickly.  Take a look at the above link and definitely get in serious strategy discussion with your Cisco AM.
HTH.
Bill
Please remember to rate helpful posts.
EDIT:  I just noticed you were asking about other apps outside of the core UC proposition.  I am not sure about ACS.  I believe that the attendant console app servers can support virtualization, but it has been a while since I have researched that and I believe there was a caveat like "maybe it is supported, we didn't test it thoroughly." ;-)
Message was edited by: William Bell
Overall Rating: 5 (2 ratings)
Correct Answer
William Bell Wed, 06/02/2010 - 07:39
  • Purple, 4500 points or more
Chad,
HTH.
Bill
chad_boone Wed, 06/02/2010 - 09:07
Thanks for the help.  Very helpful info. Exactly what I needed
Correct Answer
Jaime Valencia Wed, 06/02/2010 - 07:42
  • Cisco Employee,
  • Hall of Fame,
    2011
java
chad_boone Wed, 06/02/2010 - 09:08
Thank you for the link.  Looks like i got some reading to do but very helpful info.
