PIX 515E 6.3(5) VPN client NAT rule
Jun 2nd, 2010
i`m very new to pix and here my simple problem:
i have created a VPNClient pool from the same range as the internal ip range. For example /24 with client VPN pool of - 180. For this i have created a translation rule:
static (inside,outside) netmask 0 0
this worked fine but now i don`t want a pool frome the same network like inside
Now i have created a different IP pool - 180. But now i don`t know how the translation rule looks like?
Is this right?:
I only want the the clients from outside can connect to the internal network
Hope someone could help.
Federico Coto F... Wed, 06/02/2010 - 08:13
Hi Jason,
You don't need translation for the VPN clients to access the internal LAN.
If the internal LAN is, and if the VPN pool 192.168.1.x, you can do the following:
The problem with the above command is that the internal will not have Internet access.
Normally what you do is this:
access-list nonat permit ip
nat (inside) 0 access-list nonat
nat (inside) 1
global (outside) 1 interface
The above uses Policy NAT to bypass NAT between the internal network and the pool, and then PAT all the internal traffic to the internet.
