Enabling SSH
Jun 2nd, 2010
Hi - I need to implement SSH on 2 3600 series roouters running IOS 12.3(9). I read a few Cisco articles and although it looks easy. I cannot get it working. The commands do not work that are int h e DOC.
Can someone let me know how this is done or disable SSH altogether
Giuseppe Larosa Wed, 06/02/2010 - 08:05
  • Hall of Fame,
    Founding Member
Hello DJ Stanley,
support of SSH depends on the specific feature set the IOS image is part of
if you post
sh ver | inc image
it will be possible to check if SSH is supported on your current IOS image
Hope to help
Giuseppe
Chetan Kumar Ress Wed, 06/02/2010 - 08:11
  • Silver, 250 points or more
Hi Stanley
To enable SSH on router you can run the below command also.
ip http secure server
Chetan kumar
Federico Coto F... Wed, 06/02/2010 - 08:14
  • Green, 3000 points or more
Chetan,
The command you're referring to is to enable HTTPS on the router (not SSH).
To enable SSH first look you have a k8 or k9 image.
Please post the output of ''sh ver''
Federico.
Chetan Kumar Ress Wed, 06/02/2010 - 08:20
Hi Federico
Please try this command with k9 image & let us know the output.
It work for both HTTPS & SSH.
& If any issue let us know .
Chetan kumar
DJ214_2 Wed, 06/02/2010 - 08:55
Looks like this doesn't support. Anyway just to disable telnet. I don't really want to have to upgrade
the IOS on the 3 routers since there is always the possibility that it could go south.
SC3640-2#sh ver
IOS (tm) 3600 Software (C3640-IS-M), Version 12.3(9d), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 01-Apr-05 10:15 by dchih
Image text-base: 0x60008B00, data-base: 0x61BB8000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3640-IS-M), Version 12.3(9d), RELEASE SOFTWARE (fc2)
PSC3640-2 uptime is 28 weeks, 20 hours, 49 minutes
System image file is "flash:c3640-is-mz.123-9d.bin"
cisco 3640 (R4700) processor (revision 0x00) with 111616K/19456K bytes of memory.
Processor board ID 28724399
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
4 FastEthernet/IEEE 802.3 interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Giuseppe Larosa Wed, 06/02/2010 - 11:18
  • Hall of Fame,
    Founding Member
Hello DJ,
as Federico has correctly noted in the filename there should some special character to indicate SSH support
in your case the filename is
i
: IP subset (SNMP, IP, Bridging, WAN, Remote Node, Terminal Services)
s: (NAT, IBM, MMP, VPDN/L2F) In 11.3T added VOIP
if there was a k8 or k9 or kn with n>=4 SSH support would be present
Hope to help
Giuseppe
