LMS RME 4.3.1 Netconfig job Deploy failed
helexis
NetConfig job failed:
*** Device Details for xxxxxxxxx ***
Protocol ==> null
Message: Deploy failed.:null
Job Policies
Failure Policy: Ignore failure and continue
E-mail Notification: Disabled
Execution Policy: Parallel
Fail on Mismatch of Config Versions: Disabled
Copy Running Config to Startup: Disabled
Sync Archive before Job Execution: Disabled
Job Password: Disabled
Job Approval Details
Job Approval: Disabled
Approval List: null
Maker E-mail ID: null
Flow Type:
Device Based Flow.
Task Details
Task: ReloadSwitchIn
Commands
reload in 1:00
I have attached the netconfig job log. Can someone interpret the log and tell me why is this job failing?
Thanks!
6 Replies 6
Joe Clarke
You're missing the interactive tags required to perform a reload.  Change your template to:
reload in 1:00
Attempted the above suggestion with the below results:
ERROR:RME_CDL1022:Failed while locking the device
Job ID: 2691
Owner: crbarke
Description: test reload command on c3650crystal
Schedule Type: Immediate
Job Policies
Failure Policy: Stop on failure
Approval List: null
Flow Type:
Device Based Flow.
Task Details
Commands
reload in 1:00
Log is attached for interpretation.
Thanks!
Ok now we changed the commands to:
reoad in 1:00 y
...and it is successful but we get an immediate reload. It ignores the 'in 1:00' parameter.
Job log attached.
I think it would have worked without the 'y' but the device was locked previously.
In any event, how exactly are you scheduling this job?  Are you using the Adhoc template?
We are creating a 'User-defined Task' specifying enable mode with the command 'reload in 1:00 y'.
What appears to be happening is RME is interpreting your user-defined template as a Reload template (which doesn't support any additional options).
I cannot reproduce, though.  I created a new user-defined task called "SwitchMaintenance".  To that task, I added a templated "ReloadSwitchIn".  I made it Enable mode, and added the CLI command:
reload in 1:00y
Then I ran a job, and it worked.  I got a pop-up saying the device would reload in one hour.
