RV042 VPN to Cisco 891
Jun 2nd, 2010
Ok, I have to admit, I was spoiled using 2 RV042s to maintain a VPN, but now the client wants to put a Cisco 891 router in place and I am having hell trying to figure out all the new steps to create the same VPN connection for them.  The router at the other end is a RV042 and the one in their office will soon be a 891.  Can anyone help me with the steps on both sides to follow through?  I like the SDM on the Cisco 891, and if I can use that, that would be great :-)
Thanks!!
Federico Coto F... Thu, 06/03/2010 - 07:18
Hi Jon,
Hope this link helps you with the SDM configuration on the 891:
http://www.cisco.com/en/US/docs/routers/access/cisco_router_and_security_device_manager/25/software/user/guide/VPNS2S.html
And this link helps you with the VPN configuration on the RV042:
http://www.cisco.com/en/US/products/ps9923/products_qanda_item09186a0080a36532.shtml
If you have any questions lets us know.
Federico.
