problem restoring CallManager 4.1
Jun 2nd, 2010
hi all,
i've been trying to restore CallManager 4.1 installed in VMWare from a bakup that was made in a CallManger installed in MCS Server. i get à message indicating that there is a mismatch in the combination between the source and the destination server. i modified the hostname/IP Address parameters in my VMware to match the MCS parameters, unfortunatly i still get the same message.
any idea,  i'll be really grateful
thx in advance.
David Hailey Wed, 06/02/2010 - 13:36
  • Purple, 4500 points or more
Bilal,
Do you have the exact same version of CCM 4.1 including app upgrades and ES releases installed on the VM server you wish to restore to?
Hailey
Criss Sawyer Thu, 06/03/2010 - 02:23
hi david,
yes i do have those version on both side:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} CCM version : 4.1(3)sr4d
CCM adm version : 4.1(0.11)
CCM installation ID : 4.1(3)sr5d
BARS /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} 4.0.12000
but i did not woked...
