Centralized Management for multi-site CME set-up
Jun 2nd, 2010
  • Silver, 250 points or more
Anyone use a centralized management utility to managem multiple site CME?
I have been looking and there are a couple of products that I have found.  Before pursuing these companies I was curious to see if anyone else uses something, what it is, and if you believe it to be a valuable tool or not.
Rick
Overall Rating: 0 (1 ratings)
Jaime Valencia Wed, 06/02/2010 - 12:02
  • Cisco Employee,
  • Hall of Fame,
    2011
A few weeks ago I saw a demo of this tool, haven't worked with it but it seems to do the trick for what you're looking for. Nice tool from what they showed in the demo.
ManageExpress iManage
http://www.arcananetworks.com/html/imanage.htm
Not only you could manage the deployments separately but you could create users to manage only certain elements.
There are a couple of links on CCO if you search ManageExpress but for some reason they're not working, they hang on loading the page.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Related Content
