ADU :- No Login Popup for Manual LEAP
Jun 2nd, 2010
I am using the ADU with a Cisco CardBus card, and am trying to connect to a WLAN with LEAP Enabled.
If I set the uid / password in the profile, it works just fine !!
  However, if I select temporary password, and manual login, I do not see a popup dialog box.
  Instead the profile has "(Disabled)" added to it in the Title bar.
    i,e :Aironet Desktop Utility - Current Profile: XXX (Disabled)
Also a trace on the controller shows no 802.1x activity.
   No matter if I select Re-auth or manual login !
The driver version is
Has anyone else seen this ?
