Forwarding ports to an inside IP address?
Answered Question
Jun 2nd, 2010
I need to forward several ports to an inside IP address for video conferencing.  what is the sommnds to accomplish this? I have a Cisco ASA 5510 ver 8.0(4)23.  I need to forward both TCP and UDP ports.
thanks
Correct Answer by Federico Coto F... about 6 years 10 months ago
Paul,
''I need to forward port 1720 TCP to my inside ip address of 5.5.5.5 for example.  Then I need to forward tcp ports 60,000 and 60,1001 to inside ip of 5.5.5.5''
static (inside,outside) tcp PUBLIC_IP 1720 5.5.5.5 1720
static (inside,outside) tcp PUBLIC_IP 60000 5.5.5.5 60000
static (inside,outside) tcp PUBLIC_IP 61001 5.5.5.5 61001
The above commands will accomplish just that. (just need to change PUBLIC_IP with the correct public IP)
Federico.
Overall Rating: 5 (1 ratings)
Federico Coto F... Wed, 06/02/2010 - 10:50
  • Green, 3000 points or more
Hi Paul,
The command on the Firewall to do port forwarding is this:
static (inside,outside) tcp 200.1.1.1 80 10.1.1.1 80
The above command redirects incoming HTTP traffic on IP 200.1.1.1 to internal server 10.1.1.1
So, just follow the above command for every TCP port and change the protocol to UDP when needed.
Federico.
paul.houston Wed, 06/02/2010 - 10:55
Thank you Federico.  But let's say a specific port.
Where in your static line would i be call out the specific ports mentioned above?
Paul
Correct Answer
Federico Coto F... Wed, 06/02/2010 - 11:00
Paul,
Federico.
