Increasing Subscriber Password Security Unity 5.x
Jun 2nd, 2010
I am curious what behaviour I will see if I enforce the Phone Password Restrictions on my Unity 5.0 server. Currently all that is being enforced is minimum password length. I would like to expire passwords after 90 days, keep a 3 password history, and check for trivial passwords. Am I going to see a bunch of lock-outs? Will all users with a trivial password or a password older than 90 days be asked to change their password immediately? As you can tell this is a production system with about 1000 subscribers. Thanks in advance!
Rob Huffman Thu, 06/03/2010 - 12:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Dennis,
We just went through some similar changes when we moved to Unity
Connection. From your post I can tell you are worried about the same
issues we saw.....users HATE change (especially change that makes their life harder)
Our "old" system had a minimum 4-digit password length, never expires, and no
Trivial password check. These settings had all been decreed by a previous IT Director
Needless to say we were facing an uphill battle much like you are.
A couple of tips from our experience;
1. Make sure you let the users know over and over again about
your upcoming changes (in detail) I can't tell you how many times
I heard "nobody told me" during this process.
2. Turn off (or at least loosen) the Lock-out policy. This really doubles the
user frustration level.
3. Think long and hard about the Trivial password check...it caused us
a ton of pain!!
From Ginger;
https://supportforums.cisco.com/message/1196673#1196673
https://supportforums.cisco.com/message/1228677#1228677
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
dennis_range Thu, 06/03/2010 - 15:59
Thanks for your reply and of course communication is a big part for any change but I am curious about the actual behaviour of making these changes. Will I experience lock-outs or other unwanted behaviour after making the policy changes?
Rob Huffman Thu, 06/03/2010 - 17:25
  • Hall of Fame,
    Founding Member
Hi Dennis,
We experienced a TON of lockouts the first few days and eventually
turned it off for about 10 days. The other thing I forgot to mention in my first post
was that I would schedule this to happen for your users on a specific day
by using Bulk Edit and changing the users to "must change password at next
login". This way the whole ordeal won't drag on forever
Cheers!
Rob
Related Content
