NAC Manager HA stop responding
Answered Question
Jun 2nd, 2010
Hi guys, I have 2 CAM working in failover. 3 times this failover had stopped responding sudenly. I couldn´t managed the device through the GUI o SSH. The two devices not responded. The only way to take the control back was restarting them. They have 4.5 version.
Any that have an idea about this behavior.
Gerard
Correct Answer by Faisal Sehbai about 7 years 2 weeks ago
Gerard,
The fix is already out in 4.7 and the latest release that you can download is 4.7.2, so the fix is already out there for you to download and upgrade.
Read he release notes for 4.7.2 carefully! You have to be on the console to do the upgrade to 4.7.2 for your NAC devices.
HTH,
Faisal
Overall Rating: 5 (1 ratings)
Faisal Sehbai Fri, 06/04/2010 - 13:57
  • Gold, 750 points or more
Gerard,
4.5 and 4.6 were affected by CSCtb68853. See if your logs/symptoms match this bug.
Fix is to go to 4.7.x
HTH,
Faisal
gerardtorin Tue, 06/08/2010 - 14:44
Hi Faisal, thanks for you answer.
Yes, the symptoms are the same as the bug show.
Do you know how long for the release fixing this issue is?
Gerard
Correct Answer
Faisal Sehbai Tue, 06/08/2010 - 16:56
Gerard,
HTH,
Faisal
gerardtorin Wed, 06/09/2010 - 10:37
Thanks Faisal, I couldn't find in the releases notes that this bug was fixed. For that I asked you about it.
It was fixed but not documented?
Gerard
