visual voicemail dials 5555
arielroza Fri, 06/25/2010 - 17:07
Rob, Ahmed,
  I´m setting up Visual Voicemail on a Unity 7.0(2) ES 35 box, following the guide, and running into the same issue. Have you found a solution to this?
Ariel.
arielroza Fri, 06/25/2010 - 17:24
Ahmed,
I envy you! Sadly, I have Unity and not Unity connection, so I have no such parameter. Thanks, anyway!
Ariel.
arielroza Mon, 06/28/2010 - 10:01
Rob, Ahmed,
I found my error. I was using an extension with asterisk (*) at the beginning, which Unity seems not to like in the Call Routing Table (despite showing me no error messages).
Ariel.
