LMS 3.1: apache service error
Answered Question
Jun 2nd, 2010
After reboot Customer has this messages on windows event viewer:
Date:  5/28/2010
Time:  10:13:47
User:  N/A
Computer: FRCF1NTW10
Description:
The Apache service named; C:\PROGRA~1\CSCOpx\MDC\Apache\Apache.exe; reported the following error:
>>>; [Fri May 28 10:13:47 2010] [warn] pid file c:/program files/cscopx/mdc/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?; <<<
before the error.log file could be opened.
; More information may be available in the error.log file.;
You will find pdshow where apache is ok, file pdshow_280510_apache_ok.txt, in the morning LMS was ok except UT.
On monday, we could not connect to LMS we saw that apache.exe crashed on 28 May in the afternoon, file pdshow_280510_apache_bad.txt
We reboot lms server, then LMS is ok, UT too.
I saw conversation related to CSCsg29627 bug, Do you think that we have the same issue ?
We have an other message type in the event viewer :
Date:  5/18/2010
Time:  7:42:59 AM
User:  N/A
Description:
Apache.exe child process caused an exception and reported error
Apache.exe child process will be restarted !      .
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
and in error.log:
[Tue May 18 07:42:59 2010] [error] Apache.exe caused a EXCEPTION_ACCESS_VIOLATION in module ApacheCore.dll at 001B:6FFA8161, ap_ctx_get()+17 byte(s)
I saw a conversation https://supportforums.cisco.com/message/663665#663665 that explains this message is not important. Is it ?
Many thanks, Elisabeth
Correct Answer by Joe Clarke about 7 years 1 month ago
Not a Cisco bug, but I referred to the problem in the thread you mentioned in your initial post.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 06/02/2010 - 14:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
3.x is too generic.  Exactly what version of LMS do you have?  If less than 3.2, then you are most likely seeing the bug I mentioned in the other CSC thread.  This is fixed in LMS 3.2 as we are now using Apache 2.2.
Joe Clarke Thu, 06/03/2010 - 21:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Then you will need to upgrade to 3.2 to get around this.  Typically, this bug is non-operationally impacting.  In certain rare cases it does prevent access to LMS.  The fix was only really possible when we moved to the more recent Apache version.
ebezombes Fri, 06/04/2010 - 03:19
Bug CSCsg29627 seems to be fix on 3.1.
Do you know if there is an other bug relate to this issue which is fix on 3.2 ?
Correct Answer
Joe Clarke Fri, 06/04/2010 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
